Sinking brake pedal, not master cylinder
rugmania
Re: Sinking brake pedal, not master cylinder
Post by rugmania »
Hi Thanks for the advise. Got the brake vacuum tested, it was found to be leaking from the back,so it was replaced with a good second hand one and the problem was cured. Furthermore the turbo started to work properly and the fuel consumption back to normal. :D :D
