Parts interchangeable between D8/D9
Re: Parts interchangeable between D8/D9
Post by FarmerPug » Fri Jan 21, 2011 11:39 am
his lights were modified
Post by Gary406 » Fri Jan 21, 2011 2:39 pm
yes but not from a D9 ...
he modified his own D8 lights
D9 lights wont fit onto a D8
Catflem
Post by Catflem » Thu Feb 10, 2011 4:44 pm
Sill rubbers - are interchangeable between the D8 and D9, and are the same for saloons and estates.
I took a couple off a D8 saloon and fitted them to my D9 estate, and the D8 ones appear to be better quality as well :shock:
norrie499
Post by norrie499 » Thu Apr 26, 2012 9:39 pm
Are the front seat belts interchangeable
Post by waue1978 » Thu Apr 26, 2012 9:56 pm
norrie499 wrote:Are the front seat belts interchangeable
As far as I know they should be. Can't see there being any differences. I've got a set of the front ones in the shed from a D9. If there's a certain part of the belts that you're unsure of let me know & I'll see what these ones are like.
norrie499
Post by norrie499 » Thu Apr 26, 2012 10:03 pm
Hi Mate i need the complete belt for the from as I've got a greyhound that preferred the soft belts instead of his rubber bone. I just wanted to know before i go round the local scrappy's :)
Post by waue1978 » Thu Apr 26, 2012 10:12 pm
If you strike out on the local ones, let me know. I've got loads of bits to clear out:
viewtopic.php?f=7&t=17673
norrie499
Post by norrie499 » Thu Apr 26, 2012 10:19 pm
Cheers will do
Post by lozz » Thu Apr 26, 2012 10:52 pm
norrie499 wrote:Hi Mate i need the complete belt for the from as I've got a greyhound that preferred the soft belts instead of his rubber bone. I just wanted to know before i go round the local scrappy's :)
Imuzzle my greys when theyre in the car, saves on wear and tear of the interior :mrgreen:
Post by steve_earwig » Fri Apr 27, 2012 6:48 am
The part numbers are different, although the pretensioners are the same (I would have expected it to be the other way around). The D9 belts mention side airbags so perhaps that's the difference and the brackets angle them in different directions :? The fixing screws are different threads too. As with Mr. Waue I can't see why they'd not fit but but, without my cristal ball, I can't say they will for definite.
Post by waue1978 » Fri Apr 27, 2012 9:32 am
steve_earwig wrote:The part numbers are different, although the pretensioners are the same (I would have expected it to be the other way around). The D9 belts mention side airbags so perhaps that's the difference and the brackets angle them in different directions :? The fixing screws are different threads too. As with Mr. Waue I can't see why they'd not fit but but, without my cristal ball, I can't say they will for definite.
Best way to be sure then is to get them from the same year as your car. The ones I have in the shed matched the ones that were in the car, but they came from a W plate & my car was an X (both with side airbags).
Post by steve_earwig » Fri Apr 27, 2012 1:20 pm
Besides the great D8/D9 devide, the only differences appear to be the colours.
scoopeydiesel
Post by scoopeydiesel » Sat Oct 17, 2015 11:02 pm
Will the boot from a D8 fit a D9.
Post by highlander » Sun Oct 18, 2015 12:32 am
I seem to recall there's a slight difference in shape between a D8 saloon boot and a D9. But I could be wrong. I know the rear lights are different.
jonsowman
Post by jonsowman » Sun Oct 18, 2015 4:08 pm
Indeed, they're different shapes. The D9 one is tapered whereas the D8 is 'square'.
