Starter motor FIXED !!!
Knowledge Base Articles
Locked
Archangel
Post by Archangel » Mon Aug 30, 2010 12:22 pm
starter just making clicking noise and not turning over
Replacement !
Re: Starter motor
Post by steve_earwig » Mon Aug 30, 2010 12:48 pm
Turn lights on, try starter:
Lights dim/go out -> check battery connections -> connections ok -> charge battery/replace
Lights stay bright -> check connections -> connections ok -> suspect start motor
Hit starter motor with hammer, put car in gear and rock backwards and forwards and retry -> ok now -> plan to replace starter motor in the not too distant future.
Still no worky -> remove starter motor and check solenoid action and condition of brushes & commutator. You probably can't get spares so it's off down t' breakers.
sirwiggum
Re: Starter motor
Post by sirwiggum » Tue Aug 31, 2010 11:11 am
Excellent post.
This should be stickied!
Re: Starter motor
Post by teamster1975 » Tue Aug 31, 2010 2:14 pm
sirwiggum wrote:Excellent post.
I reckon you're right!
sirwiggum
Re: Starter motor
Post by sirwiggum » Tue Aug 31, 2010 3:00 pm
It's a handy step by step without having to get the multimeter out!
swiss
Re: Starter motor
Post by swiss » Wed Sep 01, 2010 8:26 am
And it's pitched right at my level of competence ^_^
Plus I liked the bit about the hammer
The man with no car
Archangel
Re: Starter motor
Post by Archangel » Sun Sep 05, 2010 2:33 pm
yes ,very succinct but: a) no room to swing hammer and hit starter as you can see
b)) but anyway starter has been replaced ( I have a mechanic next door but one ) and all is now well (thank god )
first 2 points on list tried first anyway and mechanic ( Hans ) had already told me that starter was suspect so had bought replacement from local factor (LVW Senar ) top notch factor (birkenhead, ellesmere port , flint , wrexham ) for those in my area . Starting is so noticeably better !!
Also note that electrical connectors can be different ( i.e. spade connector instead of nut and washer (and vice versa )
Replacement !
daniel
Re: Starter motor FIXED !!!
Post by daniel » Wed Sep 29, 2010 7:12 pm
PLEASE BEWARE EVERYONE. Do not hit a starter motor. A lot of modern starter motors have perminent magnets which are bonded to the inside of the starter motor and are quite fragile to impacts. If you hit them you are at risk of causing these magnets to break up and jam the whole motor solid. I know this from previous experience as I used to strip and fix starter motors as a job. You have been warned.
Post by steve_earwig » Wed Sep 29, 2010 7:41 pm
Thanks for the heads up!
Post by teamster1975 » Thu Sep 30, 2010 12:53 pm
I've been using a persuader on mine for the last year or so, I'd better knuckle down and replace it! :supafrisk:
Locked
