Tiny hole in exhaust - how to seal up?
Re: Tiny hole in exhaust - how to seal up?
Post by steve_earwig » Sat Dec 10, 2016 11:49 am
Check prices (then collapse...)
If the system is the same on a crocus would it be worth looking out for a full system off a wrecked one? I suspect they're much more likely to be crashed...
Post by Doggy » Sat Dec 10, 2016 4:14 pm
Pimp the Volvo to the max, use 1 day per month followed by 30 days penance in the Citroen.
Bailes1992
Post by Bailes1992 » Sun Dec 11, 2016 6:34 pm
I looked into fitting a Volvo V60 Exhaust onto my Mondeo and they wanted £600 for the full system from the CAT backwards.
I got a custom exhaust fabricated for £250 inc VAT in T304 stainless with a lifetime guarantee. Maybe worth considering? The T5 engine does sound lovely on full chat but Volvo done a good job at making it damn near silent in my Fathers V50. I imagine your S40 is the same? Bit of a grumble upto 4k and then... silence!
Or you could have them make you an exhaust even quieter if that's your thing? :roll:
2018 Volvo V40 D3 Geartronic Inscription - Mine
2019 Dacia Sandero Comfort 0.9T - Wife's
1996 Land Rover Defender 90 County SW 300TDi - Toy
2003 Ford Mondeo ST220 3.0 V6 - Other Toy
Post by Welly » Fri Mar 09, 2018 10:26 am
I can't believe this has been an issue for over a year :shock: however my excellent* idea of using high-temp mastic bound with wire has only proved a temporary fix, I guess I've renewed it maybe 4 times and lasting a few months until I forget...investigate....and find it blowing again.
Next phase is to try Gun Gum :shock: history suggests this stuff will not work but I'm more hopeful with the 'leak' being a small crack rather than a gaping hole. Reading the tin of gobbo that turned up it suggests warming the eggsauce first and then applying a bit of water whilst smoothing the repair paste into and over the hole. I've also got some stainless steel lacing wire from work which I'll use to reinforce the patch.
Repair capers to commence this weekend. Those who might say "replace the exhaust" it's not available for my Volvo unless you go main dealer or specialist aftermarket, minimum £500.00. It's one of those annoying issues, the leak can't be heard normally until you get your head down near the exhaust where its then a small but silly 'fuffing' sound reminiscent of a 1984 mini metro :(
2005 Volvo S40 T5 German Diesel botherer currently lacking front tyre grippage
trufflehunt
Post by trufflehunt » Fri Mar 09, 2018 10:57 am
I've used Gun Gum at various times over lots of years. If you get a fortnight out of a Gun Gum repair, that'll
be doing quite well.
The best repair I've ever done with an exhaust was on my 406, as mentioned above. Some adhesive aluminium
tape, ( Poundshop ) wrapped round the exhaust. Followed by some high-temperature tape that, with exhaust heat, bonds to itself.
Quik Tape is the brand that I used, but others available.
2002 VW Golf 1.9 TDI (100 bhp)
1993 Mazda MX5 Mk1 1.6
Post by Welly » Fri Mar 09, 2018 12:25 pm
Problem I have truffy is that this leak is right on the entry to the back box AND on a bend so I have about 4mm one side and loads of room the other, I can't centralise a patch over it.
I have faith in the Gun-gobbo, it will work.
(Watch this fail).
Post by Doggy » Fri Mar 09, 2018 1:52 pm
Probably not relelvant - I attempted to fix a few perforations in a Triumph Dolomite fuel tank, (when Bright Eyes was No. 1).
Failed many times with the recommended 'Petro-Patch' bodge, but some P40 fixed it first try.
Bailes1992
Post by Bailes1992 » Sat Mar 10, 2018 7:23 am
Welly, have you been to an exhaust fabricators and seen how much it would cost to get one made up in stainless steel? I paid £250 for mine at a reputable exhaust fabricator called pro-speed in Cardiff. They build it to your specification and make it sound how you want it to!
Post by Welly » Mon Mar 12, 2018 8:45 am
I haven't looked into that yet no, cheers for the idea I was kinda thinking it'd be best to buy a sport-type system from Ferrita or similar.
Anyhoo, I cleaned up the area and it's a definite 'split' about 10mm long near a chunky weld into the back box. Heated up the area with a small flame, 'wet' it first :? then squished some Gun Gum into the hole then applied more over it in layers. Introduced some stainless steel lacing wire and further layers and let it dry for 24 hrs.
This morning there was no leakage at all, watch this space....
Post by mjb » Tue Mar 27, 2018 3:56 pm
What about just getting a garage to weld it up?
