Sony aftermarket stereo working but no sound
Discodave
Post by Discodave » Tue Nov 17, 2015 8:54 pm
Hi
I've put a Sony stereo in my 2002 406 executive. It is working but there's no sound from the speakers. I tried a old goodman's stereo and it worked. The Sony one works in my vectra fine. Can anyone help ?
PeterN
Re: Sony aftermarket stereo working but no sound
Post by PeterN » Wed Nov 18, 2015 12:39 am
I would suspect that the speaker connections are different, you probably need an adaptor lead, check on ebay.
Something like this only check the radio model number. http://www.ebay.co.uk/itm/CT20PE02-Peug ... u-XMyJXwiw
Post by steve_earwig » Wed Nov 18, 2015 7:35 am
Doesn't an executive have an amplifier lurking somewhere? :?
Post by Doggy » Wed Nov 18, 2015 7:03 pm
steve_earwig wrote:Doesn't an executive have an amplifier lurking somewhere? :?
Certainly one that age will have. Maybe it doesn't get enabled unless it recognises the head unit's on?
Post by steve_earwig » Wed Nov 18, 2015 7:28 pm
So then presumably it needs a switched live from the head unit. Umm, it'd probably be important to remove it and bridge the speaker wires :shock:
2002 is probably full-mux fires up Sedre...
Post by steve_earwig » Wed Nov 18, 2015 7:53 pm
16V BA (white)
01 8420 : front LH tweeter + control
02 8422 : front RH tweeter + control
03 8410 : Left-hand front loudspeaker + command
04 8430 : Right-hand front loudspeaker + command
05 8424 : Left-hand rear tweeter + command
06 8426 : Right-hand rear tweeter + command
07 8450 : Left-hand rear loudspeaker + command
08 8470 : Right-hand rear loudspeaker + command
09 8421 : front LH tweeter - control
10 8423 : front RH tweeter - control
11 8411 : Left-hand front loudspeaker - command
12 8431 : Right-hand front loudspeaker - command
13 8425 : Left-hand rear tweeter - command
14 8427 : Right-hand rear tweeter - command
15 8451 : Left-hand rear loudspeaker - command
16 8471 : Right-hand rear loudspeaker - command
16V NR (black)
01 BH07A - fused live
02
03 8453 : Ampli - left-hand rear output command
04 8473 : Ampli - right-hand rear output command
05 8415 : Ampli - left-hand front output command
06 8435 : Ampli - right-hand front output command
07 8454 : Ampli + switch command
08 M8408 - Earth
09
10
11 8452 : Ampli + left-hand rear output command
12 8472 : Ampli + right-hand rear output command
13 8414 : Ampli + left-hand front output command
14 8434 : Ampli + right-hand front output command
15
16
I would suggest to check these with a meter while you have it in bits, rather than assume these pin outs are 100% accurate...
Discodave
Post by Discodave » Wed Nov 18, 2015 10:50 pm
Ya it has a jbl amp in the boot. I will have to have a look tomorrow in daylight
Post by steve_earwig » Wed Nov 18, 2015 11:02 pm
Don't just power it up, it'd probably simultaneously blow all the speakers...
I suspect you might want to add some crossovers in there.
Post by Doggy » Wed Nov 18, 2015 11:22 pm
steve_earwig wrote:So then presumably it needs a switched live from the head unit. [/i]
...or maybe just uses the 'comfort' VAN
steve_earwig wrote:Don't just power it up, it'd probably simultaneously blow all the speakers...
+1 Use caution
Post by steve_earwig » Thu Nov 19, 2015 12:21 am
Doggy wrote:...or maybe just uses the 'comfort' VAN
Nah, no multihex wires on the amp.
