Starclip washer
shonkers
Starclip washer
Post by shonkers » Sun Jul 29, 2018 7:17 pm
Hi guys n gals my fuel filter water sensor was leaking so i thought i'd better change the seal, as i prised off the starclip washer it went ping an flew across the road lost forever does anybody know where i can get one from, pug stealers only sell complete sensor for £37, hav'nt had any luck online i might have to get a whole filter housing at this rate cheers
jasper5
Re: Starclip washer
Post by jasper5 » Sun Jul 29, 2018 8:26 pm
Loads of starclip washers online!
Any car accessory shop will usually have a box of assorted clips...failing that nip into a local garage and ask them if they have one.
shonkers
Re: Starclip washer
Post by shonkers » Mon Jul 30, 2018 12:04 am
Yeh iv'e done all that but these are a particular size, the search continues
jasper5
Re: Starclip washer
Post by jasper5 » Mon Jul 30, 2018 3:07 pm
Starclip washers can fit many different sizes, are you sure you are looking for a starclip washer...a dome shaped washer with prongs that slip over a shaft to lock an item onto the shaft?
shonkers
Re: Starclip washer
Post by shonkers » Tue Aug 07, 2018 3:13 pm
It was a dome shaped washer with the prongs on the outside to hold the water in fuel sensor in place, anyway i couldnt get one so rather than buy a new sensor with clip and seal etc or a whole filter housing ive bodged it and glued it no leaks so far fingers crossed
