Few parts for sale 406 Saloon 2.2 HDi
Post by laceszdnb » Tue Jul 05, 2016 10:18 pm
If you interested in anything then message me here or email, laceszdnb@gmail.com
I am able to send pics as well.
-Water pump_1 (Brand new)
-Water pump_2 (Used)
-Bonnet inside cover (Used)
-Screen washer tube with fitting plastic clips (Used) This is a long bit, fitted on the bonnet and delivering the water to the jet-heads.
-Engine cover plastic, front half (Used)
-Those 3 clips and hoses, these joints on the fuel filter housing top titties (Used)
-Siemens MAF Sensor 5WK9 is the number on (Used) Made in Germany
-406 Coupe 2.2 HDi Front-Left wheel hub, bearing and balljoint are bad. (Used)
-Faulty high pressure pump,may repairable..
