gif animation creator
image removed due to potential ability to cause dizzyness
Re: gif animation creator
Argh - my eyes!
good innit, 2 things of ugliness then one thing of beauty. all at a speed that will send you crazy.
WHich is the thing of beauty? Might help if you made it all the same size...
the tap is the thing of beauty.
but heres the new sig:
it may need tuned down a bit, if anyone has a gif animator with this function give it a go.
thats cool that farmer P
Iwouidnt know where to start at making one or even get it up on the forum,
Imight have a Try when im realy-realy bored and when ive got a bit of patience,
- highlander
- PowerFlow Shill
Dude, your avatar needs to be slowed down, it's uncomfortable to look at.
I used an on-line GIF maker to put a series of pictures in sequence, and I used the slowest speed possible. Try http://picasion.com/; I don't think it was the one I used, but it certainly looks like it's easy to use.
ok i used your link quite good, an offline version would be good. the one i got seems allright except the speed settings are not there.
what do you think, and would it be possible to get the tractor in my sig to drive, it worked originally but i think it clogged up its FAP and now you just see it sitting there.
