Fuse panel image
piglet
Fuse panel image
Post by piglet » Tue Nov 28, 2017 9:31 am
In the 10 years I've had the car I've never had fuse problems.
Cars now blowing dipped beam bulbs and now it would seem a fuse.
Haynes manual has a drawing for a 'Passenger fuse panel'
But all I can find is a small one N/S in the engine bay which I assume is engine management.
And a larger panel over the drivers feet, but that is nothing like the one in the Haynes and doesn't have any numbers.
Haynes says dipped fuses are 31&32 for what it's worth.
Re: Fuse panel image
Post by steve_earwig » Tue Nov 28, 2017 10:51 am
The passenger fuse panel is above the driver's knee.
Haynes :roll: These diagrams are from somebody's handbook, they're not perfect but seem to be more accurate than most
piglet
Post by piglet » Tue Nov 28, 2017 10:56 am
Thanks for that.
Ours has only got 3 rows. I'll see if I can find the handbook, haven't seen it years though.
How is drivers RH knee passenger side?
Post by GingerMagic » Tue Nov 28, 2017 11:28 am
Passenger compartment, as opposed to passenger side of the car.... :roll:
I think the headlight fuses are little red ones in the engine bay fuse box, maybe 10 and 11 - can't remember exactly.
1999 T4 family wagon
2005 Vauxhall Meriva
Post by Doggy » Tue Nov 28, 2017 1:33 pm
+1 engine compartment fusebox, separate fuses for each main & dip beam
Post by steve_earwig » Tue Nov 28, 2017 4:57 pm
They all have, A to F are the fuses in the BSI, which is below and behind the fuse panel (over the driver's feet...)
Passenger compartment fuse panel, sorry :oops:
piglet
Post by piglet » Tue Nov 28, 2017 5:08 pm
OK, thanks all.
Post by GingerMagic » Tue Nov 28, 2017 8:09 pm
There is a handbook online if you need to look for fuses etc - go to infotec Peugeot and select your language first then model type.
It's free, which is always a bonus :mrgreen:
http://public.servicebox.peugeot.com
piglet
Post by piglet » Wed Nov 29, 2017 8:53 am
Found the long lost owners manual.
Fuse 9&10 engine bay.
One is blown. Of course I havent got any of those diddy ones.
Next question, why has it started blowing bulbs & fuses.
Post by Doggy » Wed Nov 29, 2017 1:35 pm
When a lamp filament breaks, it sometimes causes an internal short circuit that blows the fuse, (which is doing its job protecting the wiring).
Fit a new lamp and fuse, that will probably be the end of the issue.
