Warning : Brake Cleaner = Phosgene Gas
Post by steve_earwig » Fri Jan 07, 2011 8:52 pm
I came across this, I've read something like it before but I reckon it bears repeating:
Re: Interesting: Brake Cleaner = Phosgene Gas
Post by Doggy » Fri Jan 07, 2011 8:55 pm
:shock:
Post by teamster1975 » Fri Jan 07, 2011 9:37 pm
My God! :shock:
Post by steve_earwig » Fri Jan 07, 2011 10:01 pm
Nobody's seen that before? Glad I posted it then!
Have changed title accordingly. Should I sticky it?
Re: Warning : Brake Cleaner = Phosgene Gas
Post by teamster1975 » Fri Jan 07, 2011 10:05 pm
If it's that easy to gas yourself then damn right sticky it! I had no idea! (Not that I've got a mig welder mind you)
Post by steve_earwig » Fri Jan 07, 2011 10:09 pm
Got a lead lamp with an incandescent bulb in it?
Post by teamster1975 » Fri Jan 07, 2011 11:10 pm
steve_earwig wrote:Got a lead lamp with an incandescent bulb in it?
You're being silly now Steve :P
Post by steve_earwig » Fri Jan 07, 2011 11:54 pm
You spray it on the bulb, I'll watch from a safe distance
Post by mjb » Fri Jan 07, 2011 11:59 pm
:shock: :shock: :shock:
Yep, usually within a foot or two of where I'm spraying brake cleaner! :shock:
Er, not any more! This needs stickying if it's true
Post by steve_earwig » Sat Jan 08, 2011 12:15 am
I stickied it (top of the General, that ok?) I forgot to include the warning label that was along with the article, I'll shove it on now 'cos it says it all.
Phosgene Wiki
Post by FarmerPug » Sat Jan 08, 2011 5:06 am
f*ck thats scary, i never noticed, i shall take more car with this smoke off the soldering iron.
i once walked into a mushroom house, they were disinfected with Formaldehyde, i just opened the door, and looked in and instantly kicked myself away from the door, my eyes stung like mad, and i just fell on the ground, couldnt see for a few seconds. not nice stuff at all, good its not used any more.
the thing is, isnt all the fluids in a car all real bad for you, i put gloves on, because i hear some oils can make their way in through the skin.
Post by steve_earwig » Sat Jan 08, 2011 11:09 am
I'm not sure how you got from brake cleaner to solder but yes, the vapour that comes off hot flux is indeed toxic (I remember all the warnings at work when they realised :roll: ). I got this off a bike forum, further down someone mentioned chain cleaner was more or less the same.
Used engine oil is carcinogenic and can cause dermatitis (personal experience), you wouldn't want to get brake fluid in your eyes, don't drink antifreeze etc. etc. There is stuff to be worried about but in these days of totally stupid paranoia, where you need to carry out a risk assessment before getting out of bed in the morning and CORGI accreditation before opening a window, it's very easy to get overloaded with it all.
Post by FarmerPug » Sat Jan 08, 2011 11:46 pm
its easy to go ott on stuff, but on brake cleaner this should be included on the back, ie the mans story.
DRTDVL
Post by DRTDVL » Sun Jan 09, 2011 11:02 pm
brake cleaner stings when you get in it cuts
Post by FarmerPug » Sun Jan 09, 2011 11:07 pm
so does salt
