03 control stalk adapter
piglet
Re: 03 control stalk adapter
Post by piglet » Sat Sep 30, 2017 3:35 pm
All done, and to my utter astonishment works 100%.
The Autoleads PC99-213 is a faff, you have to chop the control stalk connector about to get the flying lead into it and then the Autoleads ISO jumper performs the pin swap that I had already done so I had to put it back again, but it's supplied with an uncrimped wire to go find your own switched live when there is a perfectly good one in the Pug ISO. I used the spare electric aerial crimp to patch in.
So yes, works just like a bought one.
frog
Post by frog » Sat Sep 30, 2017 9:15 pm
Nice! Glad you got it all going :cheesy: The stalk is a simple resistor network: each button activates a different resistor (see component "8413" at the bottom of the first diagram on http://406oc.co.uk/viewtopic.php?f=3&t= ... 11#p246711). Seems like the Sony radio understands this "out of the box" so the only thing needed is the correct wiring.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
piglet
Post by piglet » Sat Sep 30, 2017 9:34 pm
frog wrote: Seems like the Sony radio understands this "out of the box" so the only thing needed is the correct wiring.
The Autoleads kit includes a powered interface box which could well be packed with a quad core processor to interpret and re-code signals appropriately,
or an empty box with wires in.
It is powered though.
