03 control stalk adapter
piglet
Post by piglet » Tue Sep 19, 2017 2:17 pm
My(sons) 03 has the short dumpy radio control stalk - 6242Z6 ?
If we fit a Sony radio can we keep the column control with Autoleads PC39-125 ?
Has anyone done this successfully or is it more agro than it's worth.
frog
2.2 16v
Re: 03 control stalk adapter
Post by frog » Mon Sep 25, 2017 9:28 am
PC39-125 seems to be for CAN bus (search in http://www.armourautoretail.com/sites/a ... L2_WEB.pdf )
Peugeot 406 does not use CAN bus for the audio system, it uses a so-called "VAN bus" instead.
I think that you will need a PC99-213 (click your way through http://productfinder.autoleads.co.uk/index.htm ).
Your best chances are probably to ask directly at Autoleads, http://www.autoleads.co.uk .
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
piglet
Post by piglet » Mon Sep 25, 2017 12:32 pm
Thanks for the reply Frog.
I had already ordered the 39-125, it arrived this morning and is quite a complicated bundle of plugs & wires.
I'll have a look at the stem and see if the connectors are right.
Are there are just 2 stalk types for the 406, long thin, short fat ??
Mines the short fat (no tittering)
Post by Doggy » Mon Sep 25, 2017 12:48 pm
The compact / sturdy variant is correct for mid 2001-on cars
piglet
Post by piglet » Tue Sep 26, 2017 10:37 am
Frog, you were right, reply from autoleads:
Thanks for your email. You will need to use the PC99-213 and the relevant PC99-Patch lead i.e. PC99-SON or PC99-JVC.
I'll stick the -125 back on FleaBay.
The Sony is temporarily fitted, awaiting fascia, but can't get my head round the power management.
You turn the car off and the radio stays on so you turn the radio off, then when you put the key back in the radio powers up itself, the boy said the radio started itself when he put the key in the door! If you leave it on it does shut down by itself.
If there is a rhyme & reason, we haven't sussed it yet.
frog
2.2 16v
Post by frog » Tue Sep 26, 2017 11:59 am
You might have swapped the permanent +12Volt line with the switched +12Volt line.
Looking at the pinout diagram, the ISO connector (8 pins) "A" (outer black one):
- A 6 = +12V IGN Power (Switched via Ignition key)
- A 7 = +12V Main Power (Permanent)
Pin A 7 is closest to the fuse.
See also:
rd3pinout.pdf
(57.96 KiB) Downloaded 94 times
Note that "Switched via Ignition key" is relative, the line is not switched off directly but after some delay (10-30 seconds) after removing the ignition key. And indeed the line is switched on at any activity, e.g. opening the car using the remote control.
Current "fleet":
Previously owned:
piglet
Post by piglet » Tue Sep 26, 2017 1:36 pm
Oh, so what happened to ISO 10487 being an international standard?
So PAS/Clarion have gone with switched on 6 & permanent on 7
The rest of the world have switched on 7 & permanent on 4
I'm surprised it hasn't caught fire.
piglet
Post by piglet » Tue Sep 26, 2017 1:53 pm
What is Pin A4 '+VAN Comfort' ? Could that be illumination?
I am going to assume that A2 VAN data bus & A3 VAN data bus B will do nothing on the Sony.
frog
2.2 16v
Post by frog » Tue Sep 26, 2017 2:33 pm
piglet wrote:Oh, so what happened to ISO 10487 being an international standard?
:cheesy:
Here is a schematic that seems to be applicable: http://406oc.co.uk/viewtopic.php?f=3&t= ... ic#p246711
Looking at that, pin 7 is permanent (marked yellow), pin 6 is indeed switched directly by the ignition key. Pin 4 is switched via the BSI box, by a relay. And it is fused by MF9 (big) and by an internal (smaller) fuse in the BSI box. So no fire, at most a blown fuse. But normally a radio will run fine without blowing one of these fuses.
BTW my remark that '"Switched via Ignition key" is relative' is then applicable for pin 4, not 6. So apparently my own radio is using pin 4, as it starts up as soon as i use the remote control and keeps on playing for half a minute after i remove the key.
If all else fails, maybe use one of these :cheesy: https://www.amazon.com/Digital-Volt-Met ... B001RSREKI ?
Current "fleet":
Previously owned:
piglet
Post by piglet » Tue Sep 26, 2017 4:13 pm
Yeah thanks Frog. I have got one of those, and will check it first.
Best way to sort this is to change the ISO plug on the Sony loom rather than change the car.
Sorting the supplies should be straightforward but it's a shame I can't be more certain about additional features, dimmer, phone mute, etc.
Why must they do this???????
piglet
Post by piglet » Tue Sep 26, 2017 9:12 pm
Update,
Rewired Sony ISO, all good now. Turns on & off with key.
The only feature wired in the Sony plug was the electric aerial, which is actually correct on the Pug.
Not that I've got an electric aerial.
Post by steve_earwig » Tue Sep 26, 2017 9:15 pm
Shouldn't it run the amplifier in the base of the aerial?
piglet
Post by piglet » Wed Sep 27, 2017 10:54 am
steve_earwig wrote:Shouldn't it run the amplifier in the base of the aerial?
Frogs pinout sheet just says: 'A 5 Power to Electric Aerial'
I'll pull the pin out and see what happens.
If there's an amp it won't work without power.
piglet
Post by piglet » Thu Sep 28, 2017 7:43 am
Update:
Removing pin A5 makes no difference to radio reception.
If there is an aerial base amp it must be getting it's power from elsewhere.
Post by steve_earwig » Thu Sep 28, 2017 10:11 am
I can't see any in any of the D9 radio diagrams, I guess it was D8's (or my imagination :oops: )
