Non JBL to JBL audio system
dragunas
Post by dragunas » Fri Sep 08, 2017 2:04 pm
Hello,
I have recently purchased a JBL amplifier to fit my car. Still need to buy the JBL speakers, because the seller couldn't find them in the shed. Altogether I picked up a corresponding Clarion HU (the one from JBL system). And also I removed CD changer out of my p206, which seems to be same as in my p406. The cd changer in my car was working intermittently. My questions would be: do i need to change the wiring to power up new JBL spec Clarion HU? Wiring up the speakers is no problem, because i have a wiring loom for them. As I understand, JBL amp has only +12v, gnd and remote wires which goes to headunit? Now about speakers, as I don't have them, are the JBL speakers from sedan/wagon/coupe the same? From info I've found, coupe rear speakers are separate for bass and tweeters, while sedan rear speakers are combined with bass/tweeters. And last question, will I need to program new HU, amp and cd changer to my car using PP2000, if so, how? Thanks in advance. And sorry for a long trash post :D
Re: Non JBL to JBL audio system
Post by Doggy » Sat Sep 09, 2017 1:17 am
I cannot answer all your questions, but here goes.....
The wiring for the head unit should be the same.
You will need PP2000 to code the HU to the car - it will work if not coded, but beeps every few seconds. You need to program the HU to your car's VIN code, easy to do.
Hope that helps?
dragunas
Post by dragunas » Sat Sep 09, 2017 8:13 pm
Yes, it is clear about programming HU to car vin. How JBL amp gets power, if I leave standard loom for radio? And does jbl amp has a function, something like remote? Well, actually I am taking apart whole interior right now(because of water ingress through rear tail light :evil: ), so I think I'll manage to trace the correct wiring :wink:
Post by Doggy » Sat Sep 09, 2017 10:05 pm
dragunas
Post by dragunas » Sun Sep 10, 2017 11:46 am
Thank you! :) I have Peugeot Sedre in my laptop, but unfortunately this program can't find some wires. Like BH10C, AH29B, AH22B, XE01C. Maybe somebody can help me identify these wires?
dragunas
Post by dragunas » Sun Sep 10, 2017 7:44 pm
Sorry for double posting. I found those wires in another topic in forum. So all I need to do is trace a remote wire(8454) to headunit and splice it to my existing connector (A block, pin number 5). I will power the amp through trailer socket positive wire(20A) which is located near cd changer.
Another question is, does anybody know from what other cars (citroen?) JBL speakers are the same? I checked in Service box for 406 coupe, 607, 407, 307 and rear speakers are different to 406 sedan.
