Steering wheel volume stalk problem
peugeot30v6
Post by peugeot30v6 » Wed Dec 16, 2015 3:01 pm
Yet another problem has been added to the pile, the steering wheel volume stalk has completely died. I'm not sure if it's got a fuse or if it's connected to the radio but a little annoying when trying to change volume whilst driving. If anybody could help me out here. A new stalk is not really an option. Thanks
It's a 2002 so not the new style.
Sent from my iPhone using Tapatalk
Re: Steering wheel volume stalk problem
Post by steve_earwig » Wed Dec 16, 2015 5:23 pm
2002 would be "the new style", your car must have sat around for a bit.
Do the old stalks only do volume or does the other stuff work?
Ah crap, I thought I'd better check in case anyone suggested it and D8 stalks are different.
peugeot30v6
Post by peugeot30v6 » Wed Dec 16, 2015 5:44 pm
steve_earwig wrote:2002 would be "the new style", your car must have sat around for a bit.
Image it's completely dead, no movement on volume mode or change.
Post by steve_earwig » Wed Dec 16, 2015 6:00 pm
Does the change (mode?) work or is that borked too? Could it just need "reseating" (disconnecting and plugging in again)?
peugeot30v6
Post by peugeot30v6 » Wed Dec 16, 2015 6:33 pm
Nothing is working. I have tried to disconnect and reconnect the battery terminal but that hasn't changed anything, how would I go about resetting it, would I have to take the stalk off?
Post by steve_earwig » Wed Dec 16, 2015 9:37 pm
On the wiring diagram it looks like it's got a socket on the stalk and the other end is plugged into the MFD (why?)
peugeot30v6
Post by peugeot30v6 » Fri Dec 18, 2015 4:16 pm
steve_earwig wrote:On the wiring diagram it looks like it's got a socket on the stalk and the other end is plugged into the MFD (why?)
Thanks for the help! Took off the steering wheel column casing and found a wire had been rubbing up on the steering rack itself. Soldered back on and it works.
