Lcd screen replacement
If I replaced my screen with another from a car that didn't have satnav etc would it still work?
- GingerMagic
Re: Lcd screen replacement
Yes, the Sat-Nav screen has 2 trip computers and a nicer display - the non Sat-Nav has only 1 trip computer and a more basic display.
Its a straight swap though, and replacement bulbs for a non Sat-Nav screen are about £1 for 10 on tinterweb.
1999 T4 family wagon
2005 Vauxhall Meriva
Mine has satnav etc but screen broken so can I plug a non satnav screen in to work?
- GingerMagic
Yes, its a perfect fit.
It takes a bit to get used too, but at least you'll be able to read the display.
Please don't bin the old Sat-Nav screen, I'm after a spare....
I'm not sure it's tge correct screen as I have 2 plugs behind my screen and only one plugs in to it
I'm guessing the satnav won't work on the other screen tho?
- GingerMagic
There are often 2 plugs behind the display, I'm not sure why but the same one is used for both types of display screen.
You will lose the Sat-Nav function on the non-Sat-Nav screen - buy a Tom-Tom instead...
That's cool I can live with that as long as everything else works that's fine cheers mate
I swapped a sat nav for a non sat nav screen and I lost the remote radio function from the stalk for some reason.
2001 "51" BMW 530i sport auto in Black
2012 "62" Yamaha XT1200 Super Tenere
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750 Africa Twin
As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
2001/Y Peugeot 406 2.0 HDi Saloon
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
- GingerMagic
Ah, so maybe aim for a replacement display from a car from the same year, give or take..
I have had no issues with screen swappage, but all my 406s have been 2002 or newer ( fully mux )
Did we ever work out what the other plug was for behind the MFD ??
Ah that would make sense then as the display i used was from a semi-mux car and i put it in mux one.It made no difference as i was selling the car on so i removed the radio stalk from the column comms unit so the chap i sold the car to didn't know any differencefattail95 wrote:As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
Are you sure that "R00" is not a misspelled "A00"? misspelled by Chinese who cannot read our alphabet, or by a crappy OCR software? "A" and "R" look alikepaniya88 wrote:My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
googling "9641902577 A00" gives a long list of results, but googling "9641902577 R00" gives none ...
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
