Lcd screen replacement
BIGDAN
Post by BIGDAN » Thu Jun 11, 2015 11:15 pm
If I replaced my screen with another from a car that didn't have satnav etc would it still work?
Re: Lcd screen replacement
Post by GingerMagic » Fri Jun 12, 2015 6:24 am
Yes, the Sat-Nav screen has 2 trip computers and a nicer display - the non Sat-Nav has only 1 trip computer and a more basic display.
Its a straight swap though, and replacement bulbs for a non Sat-Nav screen are about £1 for 10 on tinterweb.
1999 T4 family wagon
2005 Vauxhall Meriva
BIGDAN
Post by BIGDAN » Fri Jun 12, 2015 3:46 pm
Mine has satnav etc but screen broken so can I plug a non satnav screen in to work?
Post by GingerMagic » Fri Jun 12, 2015 5:50 pm
Yes, its a perfect fit.
It takes a bit to get used too, but at least you'll be able to read the display.
Please don't bin the old Sat-Nav screen, I'm after a spare.... :cheesy:
BIGDAN
Post by BIGDAN » Fri Jun 12, 2015 8:33 pm
I'm not sure it's tge correct screen as I have 2 plugs behind my screen and only one plugs in to it
I'm guessing the satnav won't work on the other screen tho?
Post by GingerMagic » Fri Jun 12, 2015 9:48 pm
There are often 2 plugs behind the display, I'm not sure why but the same one is used for both types of display screen.
You will lose the Sat-Nav function on the non-Sat-Nav screen - buy a Tom-Tom instead... 8)
BIGDAN
Post by BIGDAN » Sat Jun 13, 2015 9:11 am
That's cool I can live with that as long as everything else works that's fine cheers mate
grasmere59
Post by grasmere59 » Sat Jun 13, 2015 3:19 pm
I swapped a sat nav for a non sat nav screen and I lost the remote radio function from the stalk for some reason.
2001 "51" BMW 530i sport auto in Black
2012 "62" Yamaha XT1200 Super Tenere
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750 Africa Twin
fattail95
Post by fattail95 » Sun Jun 14, 2015 10:10 pm
As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
Post by GingerMagic » Sun Jun 14, 2015 10:17 pm
Ah, so maybe aim for a replacement display from a car from the same year, give or take..
I have had no issues with screen swappage, but all my 406s have been 2002 or newer ( fully mux )
Did we ever work out what the other plug was for behind the MFD ??
grasmere59
Post by grasmere59 » Sun Jun 14, 2015 10:25 pm
fattail95 wrote:As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
Ah that would make sense then as the display i used was from a semi-mux car and i put it in mux one.It made no difference as i was selling the car on so i removed the radio stalk from the column comms unit so the chap i sold the car to didn't know any difference :oops:
paniya88
Post by paniya88 » Thu Jul 06, 2017 6:28 am
My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
frog
2.2 16v
Post by frog » Fri Jul 07, 2017 1:29 pm
paniya88 wrote:My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
Are you sure that "R00" is not a misspelled "A00"? misspelled by Chinese who cannot read our alphabet, or by a crappy OCR software? "A" and "R" look alike :cheesy:
googling "9641902577 A00" gives a long list of results, but googling "9641902577 R00" gives none ...
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
