B/P 5 Disk cd changer Activation/coded..?
Re: B/P 5 Disk cd changer Activation/coded..?
Post by steve_earwig » Thu Nov 20, 2014 8:38 pm
Interesting. I was just trying to see if that matched anything Sedre was showing me, it doesn't :roll:
fwiw
01 8497 : radio telephone/CD changer transmitter receiver earth
02 8491 : compact disc changer CAN low
03 8499 : + radio transmitter receiver Tel/CD changer battery
04 8407 : Right-hand audio CD changer command
05
06
07 8490 : compact disc changer CAN high
08 8408 : Audio earth command
09
10 8406 : Left-hand audio CD changer command
11
12
Post by lozz » Thu Nov 20, 2014 11:12 pm
Thanks steve. 8)
Post by steve_earwig » Thu Nov 20, 2014 11:33 pm
Eh? This is the HU, which I just remembered you have a pin out for (any chance of posting it?) I was seeing how this compared to the HU hook up in the link, it's obviously complete ballcocks.
This is the CD end:
01 8490 : compact disc changer CAN high
02
03 8497 : radio telephone/CD changer transmitter receiver earth
04
05 8407 : Right-hand audio CD changer command
06 8406 : Left-hand audio CD changer command
07 8491 : compact disc changer CAN low
08
09 8499 : + radio transmitter receiver Tel/CD changer battery
10 8408 : Audio earth command
(51.87 KiB) Downloaded 1 time
Post by lozz » Fri Nov 21, 2014 12:34 am
Hi,
This is what ive got for the RD4 unit:
Pin1-Ground CDC
Pin2-Data-can -Low.
Pin3-+ Battery.
Pin4-Right-Audio.
pin5-Not used N/A
pin6-Not used N/A
pin7-Can Data-High.
pin8-Audio-Ground.
pin9-Not used -N/a
pin 10- Audio/left.
Pins 11 & 12 Not used,.
Im not sure if that's correct either.. theres not many good sources for wiring diagrams out there,. :(
Again,thanks for your help its much apreciated,.
Post by steve_earwig » Fri Nov 21, 2014 7:32 am
Pfft, only thank me if I can find something useful :(
Last night I tried a whole load of different RPOs but I got the same CD diagram for everything I looked at :frown: Although at one point I must have done something different as it gave me an option for sat nav and then I got a HU with 2 aux inputs :shock: And today I can't find it again :roll:
Post by lozz » Fri Nov 21, 2014 4:01 pm
(" it gave me an option for sat nav and then I got a HU with 2 aux inputs")
Hi steve,.
there is two Aux input's.
1 of them is already wired in to something (slot marked 2 in the pic/slot marked 1 is empty)..altho im not sure what..theres no sat nav or any other tat.
just a stupid MFD set up thats s'posed to have built in diagnostic for the car etc.
the radio controls all that..so icarnt bin it and throw in something more useful,. :(
Ithink the cd changer..the ebay dude sold me is for a RD3 set up.. which is too old for the car
(38.86 KiB) Downloaded 4 times
Post by steve_earwig » Fri Nov 21, 2014 5:04 pm
It does indeed look the same as the sockets on the back of my RD3 :frown:
I saw something about someone found some sort of bluetooth plugged into one of the aux sockets. The yoyo already had something plugged into the CD player socket, I just tried unplugging it but half the dash died, obviously using it for the power for something, maybe that's all you have there.
There's also loads of stuff about a telephone microphone, a USB socket, all sorts of crap.
It's starting to look like the only thing you'll be able to do is run a socket in to the 2nd aux channel and play an MP3 player through it :frown:
Post by lozz » Fri Nov 21, 2014 10:15 pm
Thanks steve.
im just going to bin the thing and upgrade it,
just found this on ebay.. http://www.ebay.co.uk/itm/PEUGEOT-207-M ... 3f41011876
Post by steve_earwig » Fri Nov 21, 2014 10:31 pm
Fair enough mate, seems a bit pricey but it's about the same as a connects2 and it'll do everything you want without being a bodge. It's a shame the pictures are crap as you can't check the socket for your existing wiring and CD changer.
Hold on a mo, you send them your vin number, they have your address...
Post by lozz » Sat Nov 22, 2014 12:08 am
Yeah iagree..it seem's abit pricey.
there is cheaper ones on the bay/but they will be sent out needing vin coding
and the maindealer wants the Vin number for the original coding.. :(
Seen this too.. http://www.ebay.co.uk/itm/Car-Stereo-fo ... 4ac8f7aff6
again..abit pricey..and idont fancy sending that much coin to wrong kong.
Post by steve_earwig » Sat Nov 22, 2014 9:22 am
Wince
Yep, I certainly did when I saw the price :shock:
I think you can sort the vin coding thing out with PP.
Post by lozz » Sat Nov 22, 2014 4:59 pm
(I think you can sort the vin coding thing out with PP.)
its something idont have access too, :(
iactualy bought the pp2000 kit once..but it went missing in post or was never sent out in first place..
jasper5
Post by jasper5 » Mon Dec 01, 2014 2:22 pm
Lozz, I have just done one of these this morning for a customer....he bought a cable and fitted it himself and I activated it through Diagbox...couldn't get PP2000 to activate it (mine has both options). Took me 10 minutes to activate it once I worked out how to access the correct menu.
If you decide you want yours activating let me know and I'll run over with my kit.
Post by lozz » Mon Dec 01, 2014 5:28 pm
Thanks jasper.
i'still havent found the correct lead for it yet..so icarnt do anything with it,
no one seems to have one..incl the main dealer's :(
one will turn up eventualy on ebay iguess.
thanks.
