Clarion Head Units - Are semi & full mux units the same?
Post by Doggy » Thu Aug 14, 2014 12:59 pm
As title. I'm trying to find out because the original in my bro's X-reg semi-mux exec has died - smell of burning / smoke / lost half of the display on the MFD, sound distorted or off altogether.
Tried swapping for a good spare, (courtesy of gingermagic's 04 reg donor car from a year or two back), this worked perfectly for about a week, then died completely. I don't feel even slightly tempted to try mine in there.....
I've checked all the voltages etc. on the power connector, everything's correct and it has a good earth / fuses OK.
He's been searching round for a replacement, but can only find a very early D9 with a single CD slot instead of the usual exec's cassette / remote CD changer configuration. From reading the ICE section on't coupe forum, it seems the single CD ones have an integral amp so wouldn't work with the remote amp in the exec.
Apparently the very last SE versions could be selected to amplifier or speaker via PP2k, but in my ignorance I never thought to check when coding the above one to his car. :oops:
He's off on his annual trip to Scotland in just over a week and really wants a solution before then.
Any ideas? (I looked on fleabay last night - several singe CD versions to choose from but nowt else).
grasmere59
Re: Clarion Head Units - Are semi & full mux units the same?
Post by grasmere59 » Thu Aug 14, 2014 2:59 pm
2001 "51" BMW 530i sport auto in Black
2012 "62" Yamaha XT1200 Super Tenere
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750 Africa Twin
markw
Post by markw » Thu Aug 14, 2014 3:02 pm
You can get the amplified output of the CD head unit to work with an existing OEM amp by using a line level conversion loom plugged into the output of the HU to drop the levels right down so that the amp can handle them.
There's one for sale on't Coupe forum... :wink:
http://www.406coupeclub.org/PHPBB3/view ... 89&t=47478
Post by Doggy » Sat Aug 16, 2014 7:25 pm
Thanks for the info guys, he's gone for a spare from Ade the coupe breaker. Should be here Tuesday.
Post by Doggy » Sun Aug 31, 2014 9:54 am
The saga continues.....
I didn't realise that my bro's car didn't have a separate amp, :oops: (and by pure coincidence the unit fom Kelv's previous donor car was the same).
So the unit Ade sent wouldn't work - only half the buttons on the front actually did anything, then we discoverd the number '5' button was stuck in, with evidence of previous attemps to unjam it.
When I called him back about this, he sent me a replacement straight away, you can't fault that for service. :D
The first unit from Ade worked up to a point, (radio, cassette and CD changer), but had almost no volume, (which ought to have been a clue). :oops:
You can probably guess the rest by now - second unit turns up in perfect working order, and also has almost no volume. :(
So I checked the vehicle characteristics on ServiceBox....
Infallible OEM documentation wrote:RADIO RECEIVER: "RM2" RDS CASSETTE AUDIO SYSTEM
RADIO CONTROLS: REMOTE RADIO CONTROL WITHOUT CD FUNCTION
:roll:
Then I realised that if you look at the two units side by side AFTER engaging the brain, some differences are apparent. :oops:
The amplifier heat sink at the back, together with 10A fuse instead of 3A, ought to have been a clue.
Watch out for the next thrilling installment.
Seems I'm back to looking for a 99-01 exec without an amplifier.
gumby6371
Post by gumby6371 » Sun Aug 31, 2014 10:36 pm
Sorry for the hijack but do you know if I can swap the front sections over and not have to bother with the vin coding? My knob is a bit worn :lol: and the unit from my breaker is in much better condition.
Unfortunately I don't think either will fitbyour brothers motor tho.
Post by GingerMagic » Sun Aug 31, 2014 10:41 pm
Hi, yes you can swap - its 4 tiny philips screws and a clip.... :cheesy:
I rubbed my knob until all the flaky stuff came off in my hand, now I have a smooth shiny knob. :lol:
1999 T4 family wagon
2005 Vauxhall Meriva
gumby6371
Post by gumby6371 » Mon Sep 01, 2014 7:54 am
GingerMagic wrote:Hi, yes you can swap - its 4 tiny philips screws and a clip.... :cheesy:
I did take the front off the spare to see how easily they come apart, it was only whether I'd need to fire planet up for the VIN code bit if I'm just changing the Facia part I was concerned about.
Good to know you've got the unslightly flakey bits off your knob tho Kelv.
Not sure I fancy sitting alone in the car rubbing my knob so I may get my passengers to give it a little rub while I'm driving. Just hope it's not too distracting!
Post by Doggy » Mon Sep 01, 2014 12:47 pm
This ought to have 'aroused' puggy - hope he's OK?
FWIW, I've now got more flaky knobs than you could point a stick at. :roll:
Post by GingerMagic » Mon Sep 01, 2014 1:04 pm
VIN not required, I put my old black front onto my silver fronted radio no problems..
