How many 'uses' from a Clay Bar?
Whether you're just washing the car, into detailing in a big way or enhancing your 406, collect and share hints and tips here.
Post by Welly » Mon Nov 23, 2015 9:00 am
Was claying the C4 yesturday which went well but it made me realise I'd probably clayed 6 or 8 cars with the same blob of clay (which is actually two 'packs' of Meg's clay squished together).
I kept two pieces in warm water and kept stretching and reworking the stuff to a clean side but it must be pretty full of whatever it picks up off the paint.
Any recommendings?
2005 Volvo S40 T5 German Diesel botherer/i]
KozmoNaut
Re: How many 'uses' from a Clay Bar?
Post by KozmoNaut » Mon Nov 23, 2015 2:56 pm
I'd just chuck it when it starts to look grotty. If you buy the large packs of clay instead of the small consumer packets, it's a lot less expensive, so you're less likely to overuse the same piece of clay forever.
2000 406 TS4 2.2 saloon
omega
Post by omega » Thu Nov 26, 2015 6:52 pm
why use clay when blue taks cheaper and does the same job
6speedmanual
Post by 6speedmanual » Sun Dec 13, 2015 2:25 am
I have found the non branded clay bars available on ebay for under £1 a bar work just as well as the very highly priced, highly marketed brands.
These are even from uk suppliers so no need to endure shipping delays from China. The UK guys have done it for you.
Using lower priced clay means the temptation to make it last too long is gone.
Post by GingerMagic » Sun Dec 13, 2015 10:42 am
I managed to blag my neighbours clay bar as he didn't want to use it his Merc, but it is now been rolling around in the boot for a while so I guess I shouldn't use it.
I'll get some cheapies from eBay, but is the lubricant necessary of do I just keep dipping the clay in water every few seconds.?
1999 T4 family wagon
2005 Vauxhall Meriva
KozmoNaut
Post by KozmoNaut » Sun Dec 13, 2015 9:08 pm
You don't need anything special, just dipping it in water with a bit of car shampoo is fine, or use a spray bottle if you have one.
Post by Welly » Mon Dec 14, 2015 8:33 am
You can use a waterless wash spray like 'Quick Detailer' from meguires or I've has good results from mixing QD with water and car shampoo. Basically it needs to be slippy and keep spraying the panel as you pass the clay over it.
trufflehunt
Post by trufflehunt » Mon Dec 14, 2015 12:29 pm
6speedmanual wrote:I have found the non branded clay bars available on ebay for under £1 a bar work just as well as the very highly priced, highly marketed brands.
Um, where are they. I can't see any that are much less than 2 or 3 times that price..?
2002 VW Golf 1.9 TDI (100 bhp)
1993 Mazda MX5 Mk1 1.6
6speedmanual
Post by 6speedmanual » Fri Dec 18, 2015 12:18 am
I just searched having not bought any for a while. Seems 5 for £9 about par now. About s fifth the price of Meguires.
Bailes1992
Post by Bailes1992 » Tue Dec 22, 2015 11:08 am
I use the cheapest clay I can find. They're all the same. You can get varying degrees of aggressiveness but as long as you decontaminate the best you can first there is no need for some of the harsher clays.
Just use water for lube. I put my hose on a light mist and just keep wetting the clay as a pass it over the paint.
2018 Volvo V40 D3 Geartronic Inscription - Mine
2016 Dacia Duster Laureate 1.5DCi 4WD - Wife's
1996 Land Rover Defender 90 County SW 300TDi - Toy
Post by Welly » Mon Mar 20, 2017 2:29 pm
I've just been using a new clay (chemical guys I think? came in a black metal tin) it's supposed to be 'soft' anyway.
Using it with a proper clay lube (was a bit expensive buy hey ho) I was getting some proper scratchy sounds :shock: to the point I had to keep stopping to check. All was fine but the sound it made was weird, the clay appeared to be harder than the old Meg's one I used before.
