sluggish starting
johntl
sluggish starting
Post by johntl » Sun Oct 14, 2018 6:01 pm
My car is a 110 hdi 2001 done 170k
just recently the car has started to be sluggish when starting, never had a problem before, had the car 8 yrs
Its had a recon starter 50k ago
new battery less than a year ago
AC delco alternator 40 k ago
the battery is 12.7 v when stood
14.2 v under load so alternator seems to be working ok
any ideas , need to get it sorted before bad weather sets in
car gets a decent run mon - fri to work 40mls/day ???????
johntl
Re: sluggish starting
Post by johntl » Mon Oct 15, 2018 8:48 am
IS THIS THE END !!!!
WENT TO THE CAR THIS MORNING WOULD NOT START, ONLY TURNED OVER SLIGHTLY,
CALLED THE BREAKDOWN GUYS OUT , THEY SAID BATTERY FULLY CHARGED, PUT HIS BATTERY PACK ON ,STILL NO JOY !
HE TRIED 24V STILL NO JOY, HE THINKS SOMETHING HAS SLOWLY SIEZED IN THE ENGINE , DROPPED A VALVE ?????
IS THIS THE END, IF IT NEEDS NEW ENGINE THE CAR IS SCRAP !!!!
ANYBODY GOT ANY IDEAS !!!!!!
jasper5
Post by jasper5 » Mon Oct 15, 2018 10:29 am
To eliminate a dropped valve or major engine problem such as seizure, turn the engine by hand using a spanner or socket and bar (ratchet) on the crank pulley....it will be easier with the glow plugs removed.
If the engine turns normally then look elsewhere.
First thing I would check after making sure the engine turns without issue is the earth wire to the starter, then remove the starter and have it tested.
frog
Post by frog » Mon Oct 15, 2018 1:56 pm
I had the same issue. It turned out to be the starter motor.
Like you it turned over slowly so i suspected the battery at first. But that was not the problem.
My previous starter motor lasted for 2 years (~ 80 k miles)
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
johntl
Post by johntl » Mon Oct 15, 2018 6:24 pm
UPDATE:
WAS NOT ENGINE SEIZURE OR DROPPED VALVE, JUST SHOWS HOW PEOPLE CAN GO DOWN THE WRONG TRACK OF CLUES !!
GOT THE CAR TO THE GARAGE, HE TURNED THE ENGINE OVER SEEMED FINE , WHEN HE TOOK STARTER OFF AND BENCH TESTED IT THE MOTOR WAS COMPLETELY NAKT , DEAD SHORT TO EARTH
YOU GUYS WERE SPOT ON , FITTED ANOTHER STARTER AND JOB SORTED BACK ON THE ROAD AGAIN :D
SIGH OF RELIEF
PS: THE OLD STARTER WAS A RECON ONE ONLY LASTED 50K !!
Post by GingerMagic » Mon Oct 15, 2018 6:35 pm
GLAD ITS SORTED.
I HAD A SIMILAR ISSUE, THE STARTER GOT SLOWER AND SLOWER UNTIL IT EVENTUALLY GAVE UP ALTOGETHER.
BETTER THAN A DROPPED VALVE..!!
1999 T4 family wagon
2005 Vauxhall Meriva
trem1
Post by trem1 » Mon Oct 15, 2018 7:07 pm
Why are we shouting ??
Sent from my Lenovo TB-7304F using Tapatalk
PeterN
Post by PeterN » Wed Oct 17, 2018 10:11 am
If its a reduction gear gear type starter which I think most of them are when the grease in the motor gearbox dries up it will cause slow rotation, a little gear oil in there usually speeds it up.
