Rear wiper problems
caprixpack
Rear wiper problems
Post by caprixpack » Thu Aug 30, 2018 9:19 am
Came out to the gtx this morning, turned the car on and the rear wiper started going on its own. After 5 or so seconds stopped but not in the correct place. This appears to happen every time the car is started. Has anyone come across this before?
Re: Rear wiper problems
Post by GingerMagic » Thu Aug 30, 2018 9:36 am
I've got this on my estate too...
It's not the relay as you can hear it click off halfway through the sweep - but a BSI reset sorted mine.
I've also got water ingress in the drivers footwell, where the major connector running from front to back is located so worth lifting the carpet and checking the connector - it's near the pedals.
1999 T4 family wagon
2005 Vauxhall Meriva
caprixpack
Post by caprixpack » Thu Aug 30, 2018 10:28 am
Just tried a bsi reset but it didn't work. I'll check the relay next, I believe it's somewhere in the tailgate? I'll pull the carpet up too.
Post by GingerMagic » Thu Aug 30, 2018 1:02 pm
The relay slides onto the motor housing - nice and simple for a change...
caprixpack
Post by caprixpack » Thu Aug 30, 2018 1:09 pm
Cheers
caprixpack
Post by caprixpack » Thu Aug 30, 2018 1:56 pm
Just had the tailgate panel off and there's no relay or related wiring.
Anyone know where the relay board is?
Post by GingerMagic » Thu Aug 30, 2018 8:44 pm
Sorry, I forgot I had a D8 tailgate on my D9....
There are some relays down by the satnav unit, or the space where it would be, but I don't know for definite if thats where the rear wiper relay is.
