air bag ECU
NinoB
Re: air bag ECU
Post by NinoB » Sun Jul 01, 2018 10:48 am
omg... sorry about that
Re: air bag ECU
Post by steve_earwig » Sun Jul 01, 2018 12:12 pm
It's ok, not your fault, it's the crappy power company here, I think they got their plant second-hand from Namibia :roll:
frog
Re: air bag ECU
Post by frog » Mon Jul 02, 2018 7:22 am
steve_earwig wrote:
Sun Jul 01, 2018 10:42 am
it seems to have wiped out my SEDRE and Service Box doc back-up programs for both Pug and Citroen, and I can't get the keygen to work on anything, arse. Anyone? Code is ACZXMAAA .
Which version are (were) you using?
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Re: air bag ECU
Post by steve_earwig » Mon Jul 02, 2018 11:34 am
Looks like Pug 09.2011 Citroen V3.0 I think they're they will have been the same vintage. TIA!
frog
Re: air bag ECU
Post by frog » Mon Jul 02, 2018 12:45 pm
Same as i have (there also seems to be a 11.2013 version around).
"ACZXMAAA" and Country "AD" -->
For Peugeot: P4H4TSIMUJ35EHJT
For Citroen: Q2CXTMYOUB2HEHJD
Assuming you used "AD" as "Country" code; if you used another please post. The activation code seems to vary with it.
Please let me know if this worked! :D
Current "fleet":
Previously owned:
Re: air bag ECU
Post by steve_earwig » Mon Jul 02, 2018 5:19 pm
And they're back!! Thank you ever so kindly sir! :oops:
I don't remember the "AO" bit but it wouldn't have mattered, the program either wouldn't start, did nothing or crashed when I tried to use it.
And of course the repair menu says absolutely nothing :roll: There is some stuff but it's mostly about deactivation (let it stand before you disconnect the battery) and reactivation (connect the battery and reach in without getting in the way of the driver's air bag and turn the ignition on). The only other stuff is just read the fault codes, check the wiring, monkey see, monkey do :frown:
Ah well, it was worth a look.
NinoB
Re: air bag ECU
Post by NinoB » Tue Jul 03, 2018 3:03 pm
ok i will just buy it like that and fix...and will get back to u
NinoB
Re: air bag ECU
Post by NinoB » Wed Aug 01, 2018 12:30 pm
hi peeps.. now the airbag is ok, except the drivers airbag module, if i put 2 ohm resistor it clears, but when i return the airbag it comes back, i tried two different airbags but it does not work, any ideas?
