Wiring in a tow bar
Wiring in a tow bar
Post by FarmerPug » Fri Jun 01, 2018 10:45 pm
I am trying to wire in a towbar into a 2003 estate. Can i wire directly into the lights or do i need to use any fuses oe modules?
dirtydirtydiesel
Re: Wiring in a tow bar
Post by dirtydirtydiesel » Fri Jun 01, 2018 11:44 pm
The car I removed mine from was professionally fitted & that was scotch locked into the lighting circuit .
Post by Doggy » Sat Jun 02, 2018 9:28 am
To keep it legal you need a light or audible sounder to confirm the trailer indicators are working.
Easiest route is am aftermarket buzzer like this, (just the first one I found at random) https://www.ebay.co.uk/itm/Universal-To ... 0826212148
dirtydirtydiesel
Post by dirtydirtydiesel » Sat Jun 02, 2018 12:21 pm
That all came from the car I removed it from.
Farmer have you bought a new kit or a second hand one?
If you've boughta new kit everything you need sould be there.
puggy1
Post by puggy1 » Sun Jun 03, 2018 3:40 pm
Professionally fitted using scotchlocks not very professionally I always solder the joints
Post by FarmerPug » Sun Jun 03, 2018 5:20 pm
I bought a V6 estate with a factory fitted tow bar but looking at thw factory wiring it looks a tad hard to replicate. My motorfactors sold me A smart relay box. Seems to Beep If a trailer is attached, it needs a permanent positive
Anyone used BH15A from the left hand light cluster? It seems to not be used and looking at SEDRE diagrams it doesnt go through the bsi
dirtydirtydiesel
Post by dirtydirtydiesel » Sun Jun 03, 2018 9:24 pm
Just checked through my old posts,
It's terminal 4 on the near side, pop a 20amp fuse into holder 15
As I said mine was removed from another car which it had been fitted to by the after market company Towsure.
