Peugeot 406 Coupe EV conversion
frog
2.2 16v
Re: Peugeot 406 Coupe EV conversion
Post by frog » Wed Sep 12, 2018 11:31 am
I really think it is a timer. 12.2 Volt is not a depleted battery. I've seen lower voltages on my battery, but the timeout is always around those 30 minutes (on my model, that is).
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
arber333
Post by arber333 » Sat Sep 15, 2018 11:32 am
Yes :shock:
I tried to up the voltage and it still shut down on me after 30min. And i ant restart it just by starter cranking. It has to have ignition.
I have a friend that converted Citroen C2 and he had to input 11111... to BSI register to have 4000years between ECO mode trigger :lol: . Does anyone have the EEPROM position of eco mode timer on 406?
Also i would like to try to put 14V on alternator excite input. It is difficult to access alternator without dissassembly. Since i cant drive my car to a shop i need to try everything insitu before i take it there. Do you know where the wire goes?
tnx
arber333
Post by arber333 » Tue Oct 16, 2018 8:56 am
Anyone knows about "Showroom mode"? How to activate it?
tnx
arber333
Post by arber333 » Fri Jun 21, 2019 12:29 pm
Luckily i found a wire connected to alternator +12V supply. Whenever this is connected to 12V a group of relays comes on and everything in the car starts to work! Hurah! That is one single thing that enables me to start using the car as is.
ATTENTION! So i confirm this wire is the 12V signal to BSI to let the cabin systems work even though the motor IS NOT working. I think this is the way to hack your car so the stereo and internal system woul work from the battery. I will post some photos of the wire even though the loom was dissassembled from the engine. Main thing is this wire was connected to alternator contact, so it supplied 13V only when engine was working.
There is a missing link however. RPM indicator doesnt want to react to my prodding. I tried 58 pulses and it didnt work. I will need to simulate correct pulse timing if i want to wake up RPM AND some other functions that depent on it.
Speedo i noticed has a reference to RPM/KM. RPM of exit shaft is 1.3x of car speed it seems.
I will just make a circuit that i will feed motor RPM and divide that by 8 and again multiply by 1.3.
PeterN
Post by PeterN » Sat Jun 22, 2019 10:58 am
I have done a number of diesel conversions over the years but I think they would have been a doddle compared with the one you are planning. I was an electronics engineer for 50 years but I wouldn't tackle it, mind you it was all analogue and valves then, don't understand this digital stuff. I wish you success and hope you will keep us posted.
Post by steve_earwig » Sat Jun 22, 2019 11:12 am
Yes, please do keep us updated, it's all interesting and I hope you manage to get it all figured out without turning grey.
Sorry there's not been much response to your questions, it's just you are well outside the forum's comfort zone :shock:
