Multi function display
NinoB
Post by NinoB » Sat Mar 03, 2018 11:09 pm
Pls can anyone help me... How can I repair this pls..I just changed a weak battery and it became like this.. What should I do to reset it..how to repair it..
scoopeydiesel
Re: Multi function display
Post by scoopeydiesel » Sat Mar 03, 2018 11:43 pm
There is a procedure to be followed when you chance the battery unless you maintain a power source to the car. I suggest you search this forum for the procedure on how to shut down the BSI and restart it again. It may be your problem and worth a try.
NinoB
Post by NinoB » Sun Mar 04, 2018 10:47 am
I tried bsi reset it did not work..omg what should I do next
Post by GingerMagic » Sun Mar 04, 2018 5:19 pm
Possibly a fuse, I haven't got a fuse diagram to hand though....
1999 T4 family wagon
2005 Vauxhall Meriva
NinoB
Post by NinoB » Mon Mar 05, 2018 12:34 am
So you suggesting that I should check fuse..? Is there a fuse inside MFD ?or u mean bsi?
Post by GingerMagic » Mon Mar 05, 2018 7:53 am
No, I'm suggesting there may be a fuse for the trip computer or radio display..?
There is no fuse inside the MFD, but it's simple to unplug and plug back in to see if it works - just carefully prise off the two side covers ( they scratch really easy) and undo the 4 torx screws - you will lose the radio stations that are pre set but keep the trip computer.
Try fuse F in the fuse box by drivers knee, or fuse 8 - both are connected to the display and the sat nav.
