Remote locking/key programming problem
itsmeveee
Post by itsmeveee » Mon Feb 19, 2018 1:56 pm
Hi all ,
The remote locking on my 2000 406 estate has never worked since I've bought the car , I did get a remote with the car which I believe is the original one.
I've started by trying to re-sync with the key in ignition pressing the buttons etc with no luck.
I've then moved onto programming the remote with PP2000 - got the 4 digit code to do this.
Everything went fine got message saying the programming is complete , to my surprise - remote still doesn't work. :(
I've then checked BSI settings in PP2000 - Found a fault - Key not learned. :x
Tried a BSI reset and programmed the remote again - no luck.
Has anyone got any ideas what may be the problem ?
Thanks in advance.
Re: Remote locking/key programming problem
Post by Doggy » Tue Feb 20, 2018 1:45 pm
No good reason why this should work but you could try 'learning' a second key and just operate the first one twice....
They do some odd things, on my previous car I mislaid the spare remote, removed the car battery & lost sync with the remaining remote. Got the PIN code and reprogrammed it with P2k and got it working again, (all logical so far).
Some years later I found the spare remote and it worked as well. Go figure.
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Feb 20, 2018 10:27 pm
I'm afraid it Sounds like the remote that came with the car isn't the original one.
I lost mine, brought a replacement of ebay, the seller stating that it could be reconfigured.
Well it can't, new transponder fitted, key blade cut, can open car with key in lock & start BUT
When I try to sync it I keep getting key not learnt message :( .
Apparently it's to do with the security system in the bsi so that 'other keys' can't be programmed to open the car.
If you buy a new replacement key from Peugeot ( it's a virgin P.C.B) so the bsi will learn it.
Sorry I can't be of more assistance.
