Data has been deleted from BSI eeprom
keizer619
Post by keizer619 » Mon Feb 05, 2018 11:06 am
I have a 1999 406 GTX 2.0 petrol car. There has been a water leak from the rear and driver side floor has been flooded with.
When i try to start it shows Key light in the dashboard.
Then my technician checked and said Data has been deleted from BSI eeprom. Worse case is replacing all three BSI, ECU and key :(
is there any dump file for the eeprom which i we could use to write to current eeprom?
jonsowman
Re: Data has been deleted from BSI eeprom
Post by jonsowman » Tue Feb 06, 2018 6:27 pm
I suspect the data is not gone, but the BSI is non-functional. EEPROMs are very hardy devices.
You can perhaps swap the EEPROM into a replacement BSI, see here: http://www.406oc.co.uk/viewtopic.php?f= ... 7&p=235612, although yours will be a bit different since it will be a semi-mux car and therefore have a Siemens BSI.
Post by GingerMagic » Tue Feb 06, 2018 6:56 pm
When my friend David has similar issues with his car, he sorted all the faults by lifting the carpet, removing 2 gallons of water and removing the corroded connector and simply* soldering the wires together...
Initially the headlights were constantly on, the wipers and horn were not working, and the immobiliser was on.
All fixed now though.
1999 T4 family wagon
2005 Vauxhall Meriva
keizer619
Post by keizer619 » Thu Feb 08, 2018 6:42 am
Removed water but didn't solder wires and connectors , need to try that too.
Yes i saw that thread too. Currently i am having a Siemens BSI, in my case chassi number and other related information is not shown when connecting through PP2000 Scanner. I thought its because data is removed from EEPROM, then i should try to swap into another BSI and see.
