Screenwash pump removal
piglet
Post by piglet » Wed Jan 24, 2018 1:18 pm
It's bloody 'orrible outside and I don't want to snap stuff in haste.
Got the arch liner peeled back to expose the pump but it's covered in crap and hard to tell how it goes.
Does it just pull straight out of the rubber?
Ta
Re: Screenwash pump removal
Post by GingerMagic » Wed Jan 24, 2018 1:21 pm
Yes, as far as I can remember.
Don't lose the rubber part.!
1999 T4 family wagon
2005 Vauxhall Meriva
stevewalsh
Post by stevewalsh » Wed Jan 24, 2018 1:31 pm
I would hose the crap off it before pulling it out, minimise the risk of dirt getting in the tank, and you can see what you are doing
piglet
Post by piglet » Wed Jan 24, 2018 3:12 pm
Pump removed, cleaned, gently airlined, refitted.
Exactly the same. It was all fairly clean on the inside anyway.
cheap Ebay pump ordered including rubber.
Post by steve_earwig » Wed Jan 24, 2018 4:05 pm
Ah crap :( Going back to your original thread you should check the feed. It's run by 2 relays on the engine compartment board, both are normally earthed and when they're operated either relay switches to live, causing the motor to spin one way or t'other. Normally one or the other fails so you get nothing at all but it must be worth checking first.
piglet
Post by piglet » Wed Jan 24, 2018 5:14 pm
I'm making the assumption that it's not electrical as it does operate front & rear and does different things, so it must be spinning in both directions?
New pump should tell me, it was cheap enough.
I seem to remember the boy muttering something about cheap vodka for screenwash, I thought he was joking but maybe not!
piglet
Post by piglet » Fri Jan 26, 2018 1:26 pm
New pump fixed it.
Chiselled the old pump open and they are very simple, just a hard plastic impeller and a rubber diaphragm which acts as a flip-flop non return valve.
The diaphragm was looking a bit wrinkled and was very soft.
Will investigate the vodka story further.
Post by Doggy » Fri Jan 26, 2018 1:35 pm
Good result there.
406 washer reservoir holds 11 litres, would have to be very cheap vodka methinks
Post by steve_earwig » Fri Jan 26, 2018 4:57 pm
I don't remember a diaphragm :oops: Ah well, it was 10 years ago...
Ethanol does nasty things to some types of rubber, the amount they put in petrol now has disastrous effects on older fuel systems (which is why my old Yamaha started pissing fuel out everywhere :( )
They sell some pretty damn cheap varieties of vodka here, even one called Putin's.
piglet
Post by piglet » Fri Jan 26, 2018 7:46 pm
Just has a horrible thought.
I tipped the tank contents back in.
Oops
