Screen washers
piglet
Screen washers
Post by piglet » Mon Jan 22, 2018 11:55 am
I have reduced pressure on the fronts and when I squirt the rear it comes out the front as well.
Is this likely to be electrical or plumbing?
Had a quick look but it's all buried under the tank and everything is wet anyway.
Cheers
Re: Screen washers
Post by steve_earwig » Mon Jan 22, 2018 3:18 pm
The pump just has a rubber rotor that shoves water out of one outlet when it spins one way and out the other when it's reversed. Obv if something's blocked it'll take the easiest root. I had a tiny pebble in my pump that was blocking the feed for the front jets, so it only sprayed the rear whatever I did. I suspect yours will be something similar, a load of crap in the pump perhaps.
piglet
Re: Screen washers
Post by piglet » Mon Jan 22, 2018 4:01 pm
OK Ta,
I'll try pulling the pipes off the front jets and purging 1st.
Or even blowing back with an airline.
