In the 10 years I've had the car I've never had fuse problems.
Cars now blowing dipped beam bulbs and now it would seem a fuse.
Haynes manual has a drawing for a 'Passenger fuse panel'
But all I can find is a small one N/S in the engine bay which I assume is engine management.
And a larger panel over the drivers feet, but that is nothing like the one in the Haynes and doesn't have any numbers.
Haynes says dipped fuses are 31&32 for what it's worth.
Fuse panel image
Fuse panel image
Re: Fuse panel image
I think the Haynes diagram is for another model.
My manual, page 44 says it's the engine compartment fuse box, fuse no. 9 for left-hand dipped beam lights, and no. 10 for right hand. Both 15 Amps.
I think this is the one you have: http://www.autogenius.info/peugeot-307- ... x-diagram/ (scroll down to "Engine compartment fuses fuse box") , also found here: http://www.autogenius.info/peugeot-206- ... x-diagram/ (the second one, after "OR").
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Thanks Frog, will take a look in the morning.
