Replacement remote key
dirtydirtydiesel
Post by dirtydirtydiesel » Mon Apr 24, 2017 8:17 pm
As the title state's :roll:
I have misplaced :supafrisk: my remote key
It's been missing for three weeks now & it's doing my head in :frown:
I've looked everywhere but to no avail.
So the question is, can I get a replacement.
Of course as soon as I source a replacement the old one will turn up :lol:
Thanks all DDD.
Re: Replacement remote key
Post by Doggy » Mon Apr 24, 2017 10:30 pm
There's 3 significant bits of the key:
Blade - obviously only fits your locks, AFAIK a new one can be made if you have a pattern.
Circuit board - works the remote c/l - your car can be programmed via PP2k to recognise up to 5 different pcb's IF you've got the PIN code, BUT it 'forgets' any you don't operate at the time of reprogramming.
RFID, (immobilser), chip - a little black lump, (from memory) about 6-8mm square x 2 m thick - this is synched with the BSI and can't easily be changed.
If you've got a non-remote key that works, it's got items 1 & 3 above.
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Apr 25, 2017 6:17 pm
Cheers Eric,
I know all the different component's, when I first got the car I replaced the remote key case.
I am also aware of the chip being a bit of a problem.
I was just wandering if anyone had replaced one or even if it's possible.
Don't really want to start having to mess around with the bsi :roll:
dirtydirtydiesel
Post by dirtydirtydiesel » Wed Apr 26, 2017 9:38 pm
For future reference for other members.
If you've got pp2k or access to it, it's not so bad.
You can get a blank replacement off ebay for less than a tenner,
Then a used 406 key with circuit board & chip in off ebay, again less than a tenner.
You then need to get the blade cut & finally sinc chip to the b.s.i using pp2k.
There is a walk through on youtube 8)
Failing that it's £170.00 @ the main steelers :shock:
You can guess which I chose :lol:
Post by GingerMagic » Wed Apr 26, 2017 10:49 pm
Cheers for clearing this up Paul.
Some people say its not possible to use a 2nd hand key as a replacement remote key, others say its possible..
Is it a case of new ID46 chip, 2nd hand case with circuit board, use PP2000 to program the ID46 chip and sync the 2nd hand remote at the same time?
1999 T4 family wagon
2005 Vauxhall Meriva
dirtydirtydiesel
Post by dirtydirtydiesel » Mon May 01, 2017 12:06 pm
Don't know yet Kelv :oops: ,
The walk through on youtube shows a used key being done & a seller on eBay has used keys for reprogramming.
In theory it should work as when you reprogram say three keys, all the keys are reprogramed to a new code
As I understand it anyway :roll:
But I haven't tried out the theory yet :lol:
Post by Doggy » Mon May 01, 2017 1:58 pm
It's the other way rond - the BSI 'learns' up to 5 keys, if presented in the same session.
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Jul 04, 2017 9:04 pm
Hi guy's,
Bit of a update.
So I bought a second hand remote key off ebay, had it cut & guess what I couldn't programme it :roll:
So I bought a virgin ID46 chip from a auto locksmiths & happy days it worked :cheesy:
You can programme it via pp2k.
Now here's the rub :frown:
I can't get the remote to sync with the car :( , according to the seller there's 3 different circuit boards fitted.
How the hell do I work out which one I need :x
The choices are
1. 73373067C
2. 73373067B
3. Valeo
Before some bright spark says check your old one, we have misplaced it :oops:
Please can someone shed some light :?
Many thanks in advance all, DDD.
ruwds
Post by ruwds » Mon Jul 10, 2017 8:26 pm
My key's circuit board is 73373067C and the plastic key casing has Valeo stamped on it. Its from a '53 Full mux car...
I was looking at this process to help out a friend about 6 months ago but didn't proceed due to the uncertainty of success. Good to see, someone trying this out :)
2003 406 2.0 HDi 90 S
• Connects2 USB/SD/Aux • Cruise Control
frog
Post by frog » Tue Jul 11, 2017 7:09 am
Seems like the remote is programmed in the factory to match the transponder.
See http://www.digital-kaos.co.uk/forums/sh ... 3373067B-C which says:
In Citroen and Peugeot the remote is precoded with the transponder. Changing transponder makes the remote stop working. In other words transponder and remote are matched in factory. When you program new transponder it must contain also data for remote. This is needed for BSI module to recognize rf transmissions from the remote.
So it seems like the only way to get it all working is to know what data is in the remote, and from that to deduce what should be programmed into the transponder chip.
If you just program the transponder chip and then learn that key into the BSI using PP2000, the data in the remote will not match, so it will not work.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Jul 11, 2017 11:27 pm
frog wrote:Seems like the remote is programmed in the factory to match the transponder.
Arh bugger :( ,
The only thing l'll say is, you stated ( program the transponder chip and then learn that key into the BSI)
But I have used a virgin ID46 chip / Transponder, this worked learning this to the BSI.
But the remote was supplied with the correct ID46 chip to the match the PCB in the remote,
But pp2k kept coming back with (check transponder programming) when trying to sync / learn the new remote :roll:
So I am none the wiser :|
frog
Post by frog » Wed Jul 12, 2017 6:41 am
In fact only the transponder ID is "learnt" into the BSI. The BSI has no way of knowing the data in the remote (pressing the remote buttons is not part of the learning procedure).
So apparently there is something wrong the transponder ID itself? Maybe it was issued for another car model?
Current "fleet":
Previously owned:
