Center lock won't work after few seconds
paniya88
Post by paniya88 » Thu Apr 20, 2017 5:55 am
Center lock won't work few seconds after I took the key from ignition barrel
It seems like power to the doors will be cut down after few seconds. Door puddle light also turn off and Display time & radio channels reset when I turn on the key.
What might be causing this? Car is 2001 peugeot 406 2.0 16v
paniya88
Re: Center lock won't work after few seconds
Post by paniya88 » Thu Apr 20, 2017 5:17 pm
anyone ?
NinoB
Post by NinoB » Fri Apr 21, 2017 6:20 am
Try resetting your bsi
frog
Post by frog » Fri Apr 21, 2017 9:18 am
Maybe a blown fuse, from Haynes it looks like MF8 (maxi-fuse 8, "Passenger compartment fuse") or MF9 ("Built-in system interface") are good candidates to check. Maxi fuses are in the engine compartment fuse box (BM34). In some models, the maxi fuses cannot be accessed directly, they in a separate box under the normal printed circuit board; see images on https://citroenc3owners.com/citroen-c3- ... s-t36.html (search for text MAXI).
See also http://www.bba-reman.com/forums/Topic162464.aspx that seems to describe the same issue.
See also this image: http://www.mediahump.com/image/57320 .
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
paniya88
Post by paniya88 » Fri Apr 21, 2017 12:02 pm
frog wrote:Maybe a blown fuse, from Haynes it looks like MF8 (maxi-fuse 8, "Passenger compartment fuse") or MF9 ("Built-in system interface") are good candidates to check. Maxi fuses are in the engine compartment fuse box (BM34). In some models, the maxi fuses cannot be accessed directly, they in a separate box under the normal printed circuit board; see images on https://citroenc3owners.com/citroen-c3- ... s-t36.html (search for text MAXI).
Thanks frog will check that in the weekend
paniya88
Post by paniya88 » Wed Apr 26, 2017 2:59 pm
I checked the fuses and they are okay and my case after I switch off and take off the keys center lock and the door puddle lights work for about 30 seconds. then they all go dead. If I unlock the door by the key only that door will be unlocked. I tried the BSI reset also. My mechanic also have no idea about this
frog
Post by frog » Fri Apr 28, 2017 9:16 am
I summarize your issues. After contact off and removal of key, after 30 seconds:
- Radio loses all its memorised channels
- Door puddle lights turn off
- Central door locking does not work, key operates only mechanically opening one door at a time
I looked in SEDRE (the DVD with the electrical schematics) and found the following schematics (see below) that seem to be applicable to your car model.
As you say the radio loses all its memorised channels, so it must be the permanent power feed (+ 12 V) that is failing. The first schematic shows its path (indicated in yellow): Battery --> BM34 MF8 --> BH28 SH (Shunt) --> F10 . Maybe it is not a blown fuse but a broken wire?
BM34 = engine fuse box
BH28 = passenger compartment fuse box
The line via MF9 cannot be the problem, it is via this line that the BSI powers the radio for another 30 seconds after key contact off.
I also added the diagram to all the power feeds to the BSI box. And I added the diagram for the interior lighting. Hope this is helpful for you.
Radio schematic:
BSI power schematic:
Interior lighting schematic:
(108.6 KiB) Not downloaded yet
Current "fleet":
Previously owned:
paniya88
Post by paniya88 » Fri Apr 28, 2017 9:56 am
frog wrote:I summarize your issues. After contact off and removal of key, after 30 seconds:
Radio schematic:
Thanks for your reply and I just noticed that if I left the key on barrel puddle lights stay on always
paniya88
Post by paniya88 » Wed Jun 07, 2017 4:07 pm
Thanks for everyone. Finally issue has been solved. It was broken wire like you told. My mechanic checked wire harness and found the broken wire. Thanks again everyone specially frog
frog
Post by frog » Thu Jun 08, 2017 6:59 am
You're welcome. Glad you got it fixed! :D
Current "fleet":
Previously owned:
