406AC suddenly stop working
Re: 406AC suddenly stop working
Post by steve_earwig » Fri Oct 16, 2015 4:04 pm
That :arrowu: looks like an ambient air temp sensor (or it might be the one the air con uses to sense the air it sticks out). It does look kind of fried to me, which probably means something's seriously wrong with your air conditioning :(
asanka
Post by asanka » Sun Dec 13, 2015 3:35 am
hi ,
after about 2 months i just received the pp2000 interface today ,a Chinese clone .
installed diagbox 7.02 in win xp sp3 virtual machine and hoked up to diagnosis socket and run the peugeot planet from the diagbox.
then did a global scan and its only read the engine ecu ,airbag ecu and abs ecu
bsi - the ecu has not reply
air condition ecu - the ecu has not reply
then i install diagbox 5.02 and scan again so the results are same just read engine ecu, abs ecu and the airbag ecu.i am able to do configuration actuator test in engine ecu and abs ecu .
but i want to check that the ac compressor cutting in or not by using pp2000 actuator test .
is actuator test for ac compressor clutch under the air condition ecu on pp2000 ?
why it does not recognize my bsi and ac ecu ?
thanks very much
asanka
Post by asanka » Sun Apr 10, 2016 10:07 am
finally problem cured I replaced the BSI unit .soldered older eeprom to new bsi and fit to the car AC stared to work ...fine
Out side temperature on the malfunction display is still show blank --
my lexia3 still not recognizing the other ECU on the car i mentioned earlier ..
thanks verymuch
New406guy
Post by New406guy » Tue Aug 28, 2018 7:31 pm
Hey man, i would like to know what does that soldering of the eeprom has to do with the bsi? What if i didn't do so? My ac stopped working the other day and i'm still gathering information to know what to check. How much did the BSI cost you?
