BSI air con relay replacement.
Malc
Post by Malc » Sun Sep 08, 2013 7:26 pm
Will go for brevity and hope the illustrations speak for themselves.
Relay Ripca 2032 complete with loom and a smidging of soldering expertise required.
Remove and disconnect the BSI and free up all rpt all the plastic lugs (my method as illustrated) and gently prise off the BSI lid.
The relay is directly opposite the middle and lower vent slots and schematic (taken from another site) as shown directly below..
It is essential at this point to test the relay for contact failure before proceeding!!
The next step requires gentleness and patience. Gently push a small screw-driver or similar between the relay and pcb heating the solder terminals at the same time with the soldering iron. Eventually the relay will prise downwards until it is free from the pcb. Once free crush the old relay to remove from the space and clear any remaing debris.
Place the Ripca 2032 relay as shown threading the wires through the hole conveniently provided....
Wire the relay to the solder terminals as shown.
Relay wiring information. I chose this relay as others have a diode across the relay coil which will require wiring to the correct polarity.
Voila air-con up and running as new!!!!
Re: BSI air con relay replacement.
Post by Doggy » Sun Sep 08, 2013 8:03 pm
Very good how to, we'll done. 8)
Never had to do one myself, but if I did, I would certainly opt for mounting it as you have, not bring a soldering maestro.
Do you know whether the original relay had an integrated diode? (If so, you really need to add one to protect the relay driver from the reverse voltage spike de-energising the coil generates).
Post by steve_earwig » Sun Sep 08, 2013 9:19 pm
Indeed, very nicely done sir :cheesy: I've copied it over to the KB for future generations to marvel at :wink:
Malc
Post by Malc » Mon Sep 09, 2013 5:25 am
Thanks Steve a pleasure to repay all the info the site has provided me with since joining.
Doggy thanks for your posting and your comment on driver protection noted.
The original relay (now no longer available) has no diode hence my choice of Ripca 2032. See datasheet pdf from link below.
If my old 50's electrical theory is correct when the relay is de-energised there is a back EMF which delays the action of the relay somewhat and the reason for the diode (when such magical solid state devices came along) is to discharge this back EMF instantly.
http://www.digchip.com/datasheets/downl ... how=inline
Post by steve_earwig » Mon Sep 09, 2013 9:08 am
I just copied the reply to the KB (for completeness :cheesy: )
Malc wrote:(now no longer available)
I thought for a moment there that you can't tell if the old one had a diode on it because it no longer existed - you'd taken out your fury and frustration on it with a big hammer and it no longer had a physical presence in this sphere of reality :oops:
Ooh, before I forget, is the car semi-mux or full-mux? It looks like it's full from the other thread and I only thought this happened to semis.
Malc
Post by Malc » Mon Sep 09, 2013 11:34 am
The car does not have Com2000 so assume semi-mux.. One of those betwixt and between 2001 models!
If you open the pdf file in the data sheet link above and scroll down to the original relay schematic you'll see no diode but I did point out in bold that before going down the road of original relay removal/destruction check the contacts for continuity.
ie de-energised across common and NC and energised across common and NO. (0 and +12V terminals and middle top respectively in the pic with red ink schematic).
RayneR
Post by RayneR » Thu Oct 08, 2015 9:18 pm
Do you know where i can find this relay + wire harness ? thank you
edit: Found on ebay 9,90 including postage.. a bit expensive for a simple relay but i hope i will get my air con compressor up and running again :D i will ask my uncle to help me with the removal and appliance of the new relay since he have more experience with electronics.
RayneR
Post by RayneR » Tue Oct 20, 2015 1:07 am
Need a bit of help with the wiring connection because the photos aren't clear let me get this straight:
yellow -> bottom
Blue -> middle
green -> top
red -> right
Black -> left
Is this correct? MY wiring loom have different colors so i will memorize the positions.
Post by steve_earwig » Tue Oct 20, 2015 12:22 pm
I don't think the wiring loom has much to do with it, the only wiring there is for the relay which presumably comes with the connector for the relay.
Just figure out which wire does what on the relay and match it up with the diagram in the 3rd picture. Helpfully there's even a diagram on the relay.
Scream if it still doesn't make sense!
RayneR
Post by RayneR » Tue Oct 20, 2015 7:44 pm
i guess i didn't explained correctly, what i meant was the wires on the relay plug because it's not clear from the photo that wire connects to what pin in the relay plug.
So the positions is has what i described ?
Thank you
Post by steve_earwig » Wed Oct 21, 2015 7:11 am
So you're just checking the relay is wired the same? That was my worry, that'd you'd wire it up and then find it's wired differently and destroy your BSI.
I can never remember which terminal is which on a relay, probably because I seldom have to work with them. I have to work it out every time with a meter or whatever, in preference to trusting any diagram. This is useful - http://www.12voltplanet.co.uk/relay-guide.html
Looks like this Ripca 2032 is laid out type B
yellow -> bottom - can't see this but, by process of elimination it's the other coil feed pin 86 - check
Blue -> middle - pin 87a normally closed - check
green -> top - coil pin 85 - check (it doesn't actually matter as there's no diode)
red -> right - the load pin 87 normally open - check
Black -> left - 12v feed pin 30 - check
RayneR
Post by RayneR » Wed Oct 21, 2015 6:13 pm
Hmm i think you have swap two there..
black --> pin 87
red --> pin 30
has you can see the black wire pin is vertical which corresponds to the 87 because the relay is placed on another position has you can see from the other picture i have put my relay on the same position and now i know where i have to solder on the board :)
Thank you for the help... i'm waiting for my wiring loom to arrive it's taking too long as normally should coming from the UK :(
Post by steve_earwig » Wed Oct 21, 2015 6:48 pm
See? You understand it better than wot I duz :oops:
Malc
Post by Malc » Thu Oct 22, 2015 7:10 am
Not sure what you refer to as wiring loom RayneR...
My relay came complete with plug and wiring and all I did was solder it to the BSI as shown.
Don't expect it to be too easy for non-electronically inclined but it can be done.
If your relay plug is not complete with wiring suggest you get the Ripco connection diagram on your particular relay to avoid any error.
RayneR
Post by RayneR » Fri Oct 23, 2015 5:36 pm
Hi, mine didn't came with cable so i bought one apart please see the images under so i wont connect the relay in bad position... i think that the only difference in my wires are :
The yellow cable is a rose one... everything else is the same am i right? See pics:
Thank you
