Volvo Forum dishes out free DPF-delete maps shocker
It's inevitable, resistance is futile!
Post by Welly » Wed Oct 01, 2014 5:03 pm
I can't believe this, openly sharing a DPF delete software fix :shock:
As the Volvo 2.0D is essentially a HDi unit is this information likely to cross over into the Pug software?
Reading the guys instructions you'd need balls of steel to give it a go :shock:
http://www.volvoforums.org.uk/showthread.php?t=191643
Luckily you won't need to register to the horrid place to read the fred.
2005 Volvo S40 T5 a bit pampered
2010 Citroen C4 1.6 HDi turbo de' explosions
Re: Volvo Forum dishes out free DPF-delete maps shocker
Post by lozz » Wed Oct 01, 2014 6:37 pm
I've seen it happen on other forums.
And its ended up in 'rage'.
Leave them too it.. :roll:
binnzy
Post by binnzy » Wed Oct 01, 2014 6:46 pm
I've read through it, I will try most things but I havnt got the balls for that
Post by Doggy » Wed Oct 01, 2014 10:09 pm
Hmmm. Volvo owners with balls of steel? :?
One imagines there wouldn't be multitudes fitting those criteria. :roll:
Now, if I had a Volvo, I probably would go for it. It's not so different from the process for producing and installing a DPF-free version for our cars, a bit more hands on, but not terrifying to those of us who grew up with the steam powered mircoprocessors of the 80's.
I was going to say there was no way this would 'port' to a Pug, but since he's describing a conversion process and not offering a converted map, Any Pug with the same ecu, MIGHT be able to be converted in exactly the same way.
Mustard admit I had no idea said 2.0 Volvo has a real engine. :shock:
Post by Welly » Thu Oct 02, 2014 6:29 am
Doggy wrote:Mustard admit I had no idea said 2.0 Volvo has a real engine. :shock:
Yep, the very same.....just don't mention the 1.6D :oops:
The 1.8 and 2.0 Pez engines are Ford units and definitely don't suffer high oil consumption no they don't :supafrisk:
Post by DaiRees » Thu Oct 02, 2014 8:39 am
Welly wrote:.....just don't mention the 1.6D :oops:
You said what now?
That's a pug unit too isn't it? :?
Post by Welly » Thu Oct 02, 2014 10:38 am
I think so it's just that the 1.6 seems to be criticised a bit more? to be fair I've not seen any turbo fails of HP fails on the forum but I think a few have said the way the 1.6 drives seems to be variable and there's a few dealer software fixes about?
To be honest although we've heard the Pug 1.6D suffers Turbo failure it seems mostly down to neglect and not changing/cleaning a mesh filter on the oil feed, armed with this info an owner can then make sure these things are dealt with before they become a problem.
In other news my suspension is going all 'Ford' on me again I think, something's not right and I'm tired of this suspension it lets the car down it's a constant PITA. Engine and box are still stonking though as it the general condition....had it 5.5 years now :shock:
