leather seats
travers
leather seats
Post by travers » Sun Aug 06, 2017 11:09 pm
Has anyone ever tried fitting electric leather seats till a td non leather manual seat 406 ?
hullcitytilidie
Re: leather seats
Post by hullcitytilidie » Thu Aug 10, 2017 12:01 am
travers wrote:Has anyone ever tried fitting electric leather seats till a td non leather manual seat 406 ?
Yes, there's a host of information on here - just use the search facility. There is how to do stuff in the knowledge base that goes through step by step bypassing drivers seat ecu - passengers seat is straightforward. The hard bit is tracking down a good set of seats in the first place! I found the actual conversion relatively easy but had done a lot of reading on here first. Some good you tube videos as well - shows good hints at stripping out interior and seat removal and suchlike. If you get to strip everything out of a scrapper then get as much of the wiring harness as you can including heated seat switches etc.Good luck! Regards, Geoff.
2003 2.0 Hdi 110 S estate.
