How to clean ac drain line?
paniya88
Post by paniya88 » Wed Jun 28, 2017 4:54 pm
My car is leaking water in to both front footwells and it should be from the ac drain lines because this happens even on sunny days. Do I have to remove the dashboard to clean it? Thanks in advance
Re: How to clean ac drain line?
Post by GingerMagic » Wed Jun 28, 2017 11:01 pm
Hi, no need to remove the dashboard.
Undo the little torx screw which is located near the rear end of the centre console. drivers side.
Remove the ashtray ( just lifts up, maybe do the gaiter first )
Undo the torx on the inside of the console, drivers side near the gearstick.
Remove drivers side console side cover
Remove the ducting, the aircon drain is behind it - lift it away from the floor to clean it out.
1999 T4 family wagon
2005 Vauxhall Meriva
paniya88
Post by paniya88 » Thu Jun 29, 2017 3:54 am
GingerMagic wrote:Hi, no need to remove the dashboard.
Thanks GingerMagic I'll try that in coming weekends
