Will a mk 2 steering wheel fit a mk 1 (1998) 406?
telephonic
Post by telephonic » Sat Mar 19, 2016 8:19 am
Hi
I have an old 406 1998 S reg and I was wondering if I could fit a newer style steering wheel, for like a 2004 model or something? Mine is looking very worn and I do prefer the look of the newer style.
Luke
Re: Will a mk 2 steering wheel fit a mk 1 (1998) 406?
Post by GingerMagic » Mon Mar 21, 2016 11:53 pm
Hi Luke.
A 2001 onwards wheel will fit, but the airbag and airbag securing method is different. You could find an early phase 2 without comms unit (1999-2001) which has the newer style wheel but the older style airbag, which I think will be fine for your car.
1999 T4 family wagon
2005 Vauxhall Meriva
telephonic
Post by telephonic » Fri Jun 03, 2016 6:54 pm
Thanks Ginger,
I've only just spotted your reply so sorry for the delay! I think I will go for an original style then, but have now moved onto thinking about possibly something more challenging.
I have managed to find a 2002 (52 plate) model that has an entire interior for sale, and I would very much like to swap it out for mine as it is to put it kindly, ruined. Is this possible? I don't mind making small modifications to get it to work but I am fairly inexperienced (I have had the front seats out to give the carpet a clean and used to have bits of my 206 in and out for various things) but I've never changed an entire interior before.
Thanks in advance
Luke
http://www.ebay.ie/itm/PEUGEOT-406-RAPI ... Track=true
Post by GingerMagic » Fri Jun 03, 2016 8:11 pm
Okay.
The seats are a straight fit, the door cards need the metal support brackets from the later car to put into your car.
The wiring isn't so easy (electric window switch for example ) so that would be the only hurdle to over come.
If the rapier has manual seats then that's a bonus, if they are electric and you have manual then you need to spur power off the ciggy lighter, airbags in the later front seats can be left not wired in.
The steering wheel won't fit.... :wink:
telephonic
Post by telephonic » Sat Jun 04, 2016 5:42 pm
Fantastic!
I messaged the seller on Ebay before buying and the seats are manual, the seats are the main thing I'm after to be honest even if it does look a little odd not having matching door cards,but I will ask him if he can include the support brackets as well. What I didn't account for was the rear electric windows, but I've had a look around the interwebs and it appears the earlier cars may have mostly been wired up for most of the ancillaries but just not plugged in (fingers crossed) correct me if I'm wrong as I'm mainly going by what I saw from this link and the fellow replying seemed pretty well informed much like yourself.
Thanks again for your advice.
Luke
http://www.motorsforum.com/peugeot/peug ... 11557-.htm
Post by steve_earwig » Sat Jun 04, 2016 8:28 pm
Hi there. Often the wiring is there but it's not guaranteed. For instance, my D8 had the wiring present for electric seats, so did my D9, but neither had the wiring for cruise control (just one wire on the D9, one sodding wire! :frown: )
