heated seats fuse number/location 2003 rapier hdi
Re: heated seats fuse number/location 2003 rapier hdi
Post by GingerMagic » Mon Jan 05, 2015 10:53 pm
No, sorry.
My executive donor obviously has a different loom to your car and my GLX.
Scroll down to 'upload attachment' and browse for the picture, upload it and then insert it into the reply box.
1999 T4 family wagon
2005 Vauxhall Meriva
mundy1989
Post by mundy1989 » Mon Jan 05, 2015 10:57 pm
Here is the under bonnet fuse box
Under bonnetvfuse box
mundy1989
Post by mundy1989 » Mon Jan 05, 2015 11:06 pm
Here is the in car fusebox
In car fusebox
mundy1989
Post by mundy1989 » Mon Jan 05, 2015 11:07 pm
Another pic
mundy1989
Post by mundy1989 » Mon Jan 05, 2015 11:09 pm
This is all the switches do, that's if the sidelights are on
Heated switches
Post by GingerMagic » Mon Jan 05, 2015 11:48 pm
I don't really want to state the obvious, but have you tried to power to the brown plug with the engine running......
My donor exec has an extra piece of loom towards the back of the engine fusebox in the first picture, but my GLX is identical to yours i.e.no extra loom or relays. I haven't got mine working yet but I'll look at the BSI in daylight to see what spaces are there.
Post by steve_earwig » Mon Jan 05, 2015 11:54 pm
Yeah, the lights in my switches did that, it's a different circuit so it's meaningless.
mundy1989
Post by mundy1989 » Tue Jan 06, 2015 12:02 am
I did try, can the heater elements be hardwired ie live feed from battery to the brown plug?
Post by GingerMagic » Tue Jan 06, 2015 12:12 am
I asked Mark W the same question a while ago, and here is his reply..
'As regards the engine running relay, if you can't get one installed, just opt for the slightly less elegant solution of having the heaters fed from an ignition controlled supply. The elements consume about 4A each and the idea of having them controlled by an engine running relay is to prevent them being on with engine off (obviously!(sic)).
Put them on an ignition feed instead....you're hardly likely to sit in the car with just the ignition on and the heaters switched on.....
You can switch the individual heater loads directly with the seat heater switches, no relay needed there. That's what they do anyway (switch the full load), it's just the engine running relay that supplies them.'
Does this help?
grasmere59
Post by grasmere59 » Tue Jan 06, 2015 12:27 am
Could you use something like this http://www.ebay.co.uk/itm/30-AMP-SELF-S ... 23396a2978 , It will only give power when the engine and charging is running and cut out when the engine stops.
2001 "51" BMW 530i sport auto in Black
2012 "62" Yamaha XT1200 Super Tenere
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750 Africa Twin
mundy1989
Post by mundy1989 » Tue Jan 06, 2015 11:06 pm
I have wired them direct to battery with a good earth still no good, I'm assuming the elements have both had it, :(
Post by steve_earwig » Tue Jan 06, 2015 11:11 pm
oh bugger :(
mundy1989
Post by mundy1989 » Tue Jan 06, 2015 11:20 pm
Hopefully the right way round using yellow/green as earth
mundy1989
Post by mundy1989 » Tue Jan 06, 2015 11:21 pm
I'll wait until we get an executive in at work and have the fronts out
