Water leak
straggler
Water leak
Post by straggler » Thu Feb 23, 2017 3:04 pm
I have a 96 406 saloon which is collecting water in the boot. The nearside rear of the mat gets wet in the rain. It's not coming from the boot lid as it's just the mat. After heavy rain it pools in the corner and makes the trim surround it wet. Any idea as to where to look for a leak?
Cheers.
frog
Re: Water leak
Post by frog » Thu Feb 23, 2017 3:15 pm
I had the same problem. It turned out that the water was coming in via one of the the tail lights.
You might want to check the spare wheel. Mine was swimming :D
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
straggler
Re: Water leak
Post by straggler » Thu Feb 23, 2017 3:29 pm
That sounds like a plan. I'm abroad at the moment and don't want to start dismantling things so will check it when I get back. Stuffing newspaper under the mat in the meantime!
straggler
Re: Water leak
Post by straggler » Thu Feb 23, 2017 3:52 pm
Just discovered I have water in the front passenger footwell too. This has been a longstanding problem I thought I'd sorted out (thought it was a coolant leak as the coolant needed frequent topping up) but now guessing not!
dirtydirtydiesel
Re: Water leak
Post by dirtydirtydiesel » Thu Feb 23, 2017 9:29 pm
Hi,
Is the rubber seal that runs along the length of the sill still there & intact,
clumsy feet can dislodge it/damage it this in turn allows road spray to get under the doors & run
down in to the footwells :roll: ,another favourite is blocked up sunroof drains (if you have one)
straggler
Re: Water leak
Post by straggler » Thu Feb 23, 2017 10:25 pm
dirtydirtydiesel wrote:Hi,
It happens when the car is standing for a while.
Where would I find the sunroof drains?
dirtydirtydiesel
Re: Water leak
Post by dirtydirtydiesel » Thu Feb 23, 2017 11:14 pm
Search for (sunroof woes & cures with pictures).
It's well documented on here & you've been a member longer than me :wink:
straggler
Re: Water leak
Post by straggler » Fri Feb 24, 2017 10:24 am
I found the post. Thanks.
Any idea how I can remove the trim panels on the A pillars? The original poster says they are on clips but mine seem reluctant to move and I don't want to force them....
Re: Water leak
Post by GingerMagic » Fri Feb 24, 2017 2:05 pm
Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
There are some spring clips in he back of the trim, which locate into square holes in the pillar, these can be a bit stiff.
1999 T4 family wagon, slow as a turd but the kids like it
2002 Citroen Xsara Picasso Hdi90 - Dirtied by the kids, Dented by the wife....
Sadly sold the 406, best cars I have ever owned
straggler
Re: Water leak
Post by straggler » Sat Feb 25, 2017 10:57 am
GingerMagic wrote:Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
Nice one, thanks.
I'm abroad at the moment so will wait until I'm back in the UK before fiddling with it.
