Rock hard brake pedal !!!
dirtydirtydiesel
Post by dirtydirtydiesel »
As the title state's
Jumped in the old girl tonight after work, drove across the car park put my foot on the brakes :shock:
W.T.F rock hard brake pedal & no brakes :shock: , managed to get her to stop ( luckily I wasn't going very fast)
Pressed the brake pedal really hard & it worked :roll:
Pumped them a few time's before driving home very gingerly :?
I have no faith in them now, Anyone got any ideas / heard of this before
All advice appreciated, many thanks DDD.
trem1
Re: Rock hard brake pedal !!!
Post by trem1 »
Was the vac pump on my first 407,scared the sh*t out of me when it first did it.
Sent from my K013 using Tapatalk
frog
Post by frog »
Same problem as this one?
Or would have except the pedal didn't move! Luckily I was going slowly and the handbrake managed to bring it to a halt. Moved off, very slowly and applied brakes again, pedal went down but I could feel it grinding a bit through the pedal. Managed to limp it home through the quiet backstreets and have left it there since, it was just downright bloody dangerous!
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
PeterN
Post by PeterN »
Yes sounds as though have no vacuum, the brakes aren't very good without it :shock: Either the vacuum pump as mentioned or the brake servo or a vacuum leak somewhere. If its an Hdi there won't be much turbo boost either, just changed mine for that reason and it improved the brakes as well. Check the solenoids on the bulkhead behind the top of the engine for leaking rubber pipes.
dirtydirtydiesel
Thanks for the imput guys,
No frog not like that,
Quite sure now having been reading up on the subject that the servo non return valve is fubared :roll:
Spoke to my local steelers, gonna order one in the morning.
I'll post up the results.
DefTrap
Post by DefTrap »
Think the servo non return valve has gone on my HDI 90 as well.
These parts are hard to track down online or am I searching for the wrong thing?
Can anyone point me in the right direction? If someone has the p/n for a servo check valve for a 2002 HDI 90 that would be grand.
Looks like
4599 31 BRAKE AMPLIFIER KIT
BOSCH. -
- EXCEPT EW10D INJECTION
Not sure if this is right but it's where I'd expect to find it...
dirtydirtydiesel
Yup , that's what I bought steve :D
DefTrap
Post by DefTrap »
steve_earwig wrote: Mon Apr 09, 2018 5:09 pm Looks like
BOSCH. -
Awesome, thanks.
DefTrap
Post by DefTrap »
dirtydirtydiesel wrote: Mon Apr 09, 2018 11:08 pm Yup , that's what I bought steve :D
Was that the part that fixed the issue on yours in the end?
dirtydirtydiesel
It was this time round for me but it can also be the servo it's self and or the vacuum pump.
I just went for this first as it's the easiest and cheapest. :)
stevewalsh
Post by stevewalsh »
Replaced servo on mine, Not an easy job with the engine in
PeterN
Post by PeterN »
Failure of the vacuum pump will affect the turbo boost as well, so if yours goes OK it will be a servo fault.
DefTrap
Post by DefTrap »
Well the garage diagnosed mine as a servo issue, so they're doing it today. ;)
I hope they're trustworthy...
"Nah, sorry mate, you're gonna need a whole new car." :shock:
