OEM wheels for brembo V6
thomasrs50
Post by thomasrs50 » Tue Aug 08, 2017 6:12 pm
Hi all
I'm new to the forum, so will present myself in the appropriate thread.
In the meantime, I'm wondering what OEM Peugeot wheels will clear brembo V6 brakes without the use of spacers? There is a set of 207 Hockenheim wheels (17 inch) I can have for little money, but would they f.i. fit?
It would like the wheels to be 17 or 18 inch and blend in with the OEM 406 look.
Thomas
peo
Re: OEM wheels for brembo V6
Post by peo » Wed Aug 22, 2018 8:37 pm
Yes, normally you can use same alloys from 406 coupe. I can show an image from my 406 saloon with Brembo calipers and no spacers.Image
Peugeot 406 HDI SR Pack Fase II 2004 with Brembo calipers and strut force
Post by GingerMagic » Wed Aug 22, 2018 9:00 pm
Those 'Tacoma' alloys are so rare in the UK, sadly, as these are one of my favourite wheels..
Although I also like the Lincancubar alloys on notrix's car :cheesy:
1999 T4 family wagon
2005 Vauxhall Meriva
dirtydirtydiesel
Post by dirtydirtydiesel » Thu Aug 23, 2018 10:52 am
Hi all
Thomas
To the best of my knowledge there are no Peugeot oem wheels which are 17" / 18" that don't require a spacer to fit a 406
The 406 with brembo calipers require's a off set of 12mm which is very small most of the other offerings are between
30 & 35 mm offset.
peo
Post by peo » Thu Aug 23, 2018 12:45 pm
Exactly all 406 coupe alloys models are 16 inches with ET12 offset and all these ones are fully compatible with Brembo calipers. But other alloys models are not compatible with Brembo it you doesn't use spacers.
Post by GingerMagic » Thu Aug 23, 2018 1:03 pm
With the exception of the 15" Starfish alloys on the 2.0ltr petrol models - these are not suitable for Brembos.
fattail95
Post by fattail95 » Thu Aug 30, 2018 6:49 pm
I'm currently running the 16" Coupe Starfish alloys on my saloon -- will I be able to upgrade to brembos?
Post by GingerMagic » Thu Aug 30, 2018 8:42 pm
Yes, no problem.
You will need the calipers, and also the brake pipes to suit as the bleed nipples are in a different place on the Brembos - I got a set from HEL online for £33.
Post by mjb » Mon Sep 03, 2018 5:17 pm
"upgrade" is not the correct word to use there... The soggy, squeally, expensive and difficult-to-maintain brembo brakes are by far the worst part of the v6 coupé. When I had mine I wished I'd upgraded to brakes from any other 406.
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Sep 04, 2018 11:29 pm
mjb,
Dare I say it but yours must have been poorly maintained then because if in good condition & with
the correct pads / disc's they display none of the above traits (except expensive) & are a huge improvement over
Single piston sliding calipers :roll:
peo
Post by peo » Sun Sep 09, 2018 4:28 pm
I don't have any problem with normal use at my 406 saloon. I believe these calipers increase the security.
