Brake lines
Blue
Brake lines
Post by Blue » Tue Apr 04, 2017 1:31 pm
Hello All
Can anyone please tell me what size brake spanner i need to undo the metal brake pipe, that will seperate the metal pipe from the rear brake caliper. 406 hdi 90 rapier 2002.
Dave (Blue).
jasper5
Re: Brake lines
Post by jasper5 » Tue Apr 04, 2017 5:22 pm
Blue wrote:Hello All
Dave (Blue).
11mm if it's the original pipe, probably 10mm if it's been replaced at some point.
PeterN
Re: Brake lines
Post by PeterN » Tue Apr 04, 2017 10:30 pm
..or 7/16" in old money...
scoopeydiesel
Re: Brake lines
Post by scoopeydiesel » Tue Apr 04, 2017 10:47 pm
You will need a special brake nut spanner as an open end one will slip. Its basically a ring spanner with a slot to slide over the pipe. Search under brake spanner wrench :)
