heavy steering
dirtydirtydiesel
heavy steering
Post by dirtydirtydiesel » Mon Jun 20, 2016 7:32 pm
Hi all,
Fitted a new clutch kit & dmf over the weekend, pig of a job but well chuffed with the results.
Just one or two glaring problems :roll:
1. To get the box out I had to lower the subframe slightly, about 40mm at the front & 10mm at the back
Now probably stupidly I didn't loosen the rack or column :oops:
Upon finishing the job & going for a road test I found the steering to be a bit tight / heavy & not quite self centring.
Any ideas, bent column / damage to the rack
2. Powerflex rear / lower stabiliser bush, DON'T DO IT!!!!!!!! :x
On a derv anyway, it vibrates like a Motherfxxker on idle, might be great in a chaved up 306 with a drain pipe exhaust
But on my family estate bus used to tow our caravan not so great :evil:
So guess what I'm doing next weekend :frown:
jasper5
Re: heavy steering
Post by jasper5 » Mon Jun 20, 2016 10:11 pm
I've done lots of these and always lowered the subframe without touching the rack and never had an issue.
I would run it a bit longer and see how it goes.
dirtydirtydiesel
Re: heavy steering
Post by dirtydirtydiesel » Tue Jun 21, 2016 7:45 pm
Thanks for the imput jasper,
I am not imagining it, it's definitely stiffer & not self centring.
I have studied some diagrams of the rack & column assembly & I am convinced that I have damaged the lower UJ that
connects the column to the rack.
Maybe I was unlucky & didn't have it in the correct orientation when I lowered the subframe & you did every time without knowing.
I don't know if this is right but what I do know is mine is damaged some where & that looks like the culprit :roll:
