My GTX
dirtydirtydiesel
Re: My GTX
Post by dirtydirtydiesel » Fri Mar 23, 2018 11:39 pm
Welcome to french car ownership :lol:
No seriously though I've had two for six years now & never had a problem with the bottom hose :cheesy:
Running for cover :supafrisk:
Lot's of other stuff though :roll:
caprixpack
Re: My GTX
Post by caprixpack » Tue Mar 27, 2018 4:37 pm
Fingers crossed the bottom hose has sealed, and hopefully it stays that way.
Also I found a new tailgate moulding, thanks to a guy off Facebook so I'll get that prepared and painted tomorrow if I get time.
Another thing, it does seem woefully underpowered. I believe it's back to how it should be but it's still slow, so I'm looking at remapping it. I'm quite happy to do it myself, I did our passat last year and it's transformed the car. Does anyone have any recommendations where I can obtain a map file from?
Re: My GTX
Post by mjb » Wed Mar 28, 2018 5:07 pm
could be worse... could be german!
When flogging the 540i, I got nearly 50 messages in my ebay inbox asking questions like:
* When was the cooling system replaced?
* How long since it last got a new radiator?
* Are any of the coolant hoses original?
* How often does the coolant need refilling?
* Does the fan work properly?
* Does the heating get warm?
* Does the heating stop getting warm when you turn it to cold?
a 20 year old bit of plastic or rubber rotting and becoming brittle is one thing, but those E39s had proper cooling issues! :shock:
Re: My GTX
Post by GingerMagic » Wed Mar 28, 2018 5:23 pm
The Hdi takes a bit of getting used to, it's not a huge shove in the seat when on boost like the old Xud diesels, or indeed the PD engines, but it's more gentle and so across the revs - but it should still hustle along nicely..
Try Hdi tuning in Bristol, the guy is called Steve and he can send you an off the shelf map, or you can send him a copy of yours and email it over to him so he can customise it and email it back.
You'll get 140+ BHP and a more useable range.
Other places offer the same service, but Steve has mostly positive response.
1999 T4 family wagon, slow as a turd but the kids like it
2002 Citroen Xsara Picasso Hdi90 - Dirtied by the kids, Dented by the wife....
Sadly sold the 406, best cars I have ever owned
caprixpack
Re: My GTX
Post by caprixpack » Wed Mar 28, 2018 6:16 pm
I had seen hdi tuning while having a browse, just wondered who was recommended. The hdi does seem a to be smooth and gentle. I guess I'm too used to the passat, boost comes in quite low down and pulls hard right up to the red line. Anyway I'll give them a go.
Not sure what BMW are like but my 924 and passat for the most part seem to be over engineered especially the 924, compared to them the 406 seems a bit flimsy but I guess that's just the French way my wife's old 106 was the same. The whole bleeding nonsense is what annoys me the most when trying to sort out the leak, it takes bloody ages and with 3 bleed points.where as the passat is a case of fill the header tank run it up to temperature them top up the tank. The porsche is equally as easy, fill the header tank take the bung out run it up to temperature and put the bung back in when the water comes out.
caprixpack
Re: My GTX
Post by caprixpack » Tue Apr 03, 2018 1:45 pm
Not a big update but at least it looks a bit smarter now.
caprixpack
Re: My GTX
Post by caprixpack » Thu Apr 05, 2018 2:30 pm
Ffs here we go again.
After the bottom hose started leaking again I ordered several rubber seals with different cross sections and inner diameters. The original seal, the one that came with the radiator and the one that came with the new hose were all too small. I found that the seal that fit the best had an inner diameter of 31mm and a cross section of 5mm, the fitting now fits snugly and securely and hopefully keeps the coolant in place.
caprixpack
Re: My GTX
Post by caprixpack » Sat Apr 28, 2018 10:04 pm
Had a bit of bad luck yesterday :( a 6" nail stuck in the tyre, as usual too close to the side wall to plug and patch i also didn't notice until it was getting very low so tyre would have been buggerd either way.
Anyway I dropped the wheel off to have a new tyre fitted this morning so it's all good again. Also this arrived this morning.
The air conditioning wouldn't blow cooler than 14°c, after emptying the cam into the system it now blows around 5-6°c. Probably not as cold as I can be but it will do for now.
