Replacement daily hack!
dgt
Post by dgt »
Howdy all!
Replaced the current silver 406 with a regency red 406. 164k miles, drives beautifully, looks fantastic. I'm delighted :cheesy:
It isn't without it's problems (what car is? How boring that would be!) but they're minor and relatively easy to fix..... :lol:
So what's wrong with it?
  • Fuel flap not opening
  • Airbag light flashing
  • Damp inside
  • Broken foglight
  • Water filled tail lights
  • Clonking from the front
  • A small bit wobbly behind
  • A few dents
And a knackered turbo :frown:
However, I do have some other plans for it when it's running and finances permit:
  • Projector lights
  • Lowering
  • An unusual set of wheels
  • T25
  • A custom pump
And hopefully leave it at that :cheesy:
But enough yap, time for pictures :D
Starting with a walk around of the car
The foglight damage
Interior
And the boot
Needs a slight clean!
Always nice to see a near full toolkit :cheesy:
Tail lights filled with water
So the first fix was the gaiter ad ashtray, which was sticking
Now with an ashwood ashtray :D
Now, to sort the back out
No point flutein' around with torx bits and vortex sockets, vice grips and impact socket
And in no time, it's off
They needed changing and are a help when changing the link rods (I found anyway)
Time for an allen bit and vortex sockets...
Then onto the eccentric bolt... No room and no room :(
Didn't want to come out, so swung it round and out it popped
Out with a new one
Clean the bolt, nut and washer then apply copper grease
And the whole lot flew on :cheesy:
One side done
To the other side, thought this looked odd...
Yep, broken drop link
Cable tied to the arb :roll:
I got them out though
The link on that side didn't want to play ball!
Alas, same procedure as the other side and all on. Just needs tracking!
Onto the tail lights
Lack of
New(ish) ones
Last for now is the foglights
Beyond economic use!
And painted the other side yellow :D
A bit done, plenty more to do :cheesy:
Re: Replacement daily hack!
Looks alright that mate, 8)
Re: the projector lights, are you making your own, ?
jonsowman
Post by jonsowman »
Good stuff, always nice to see D8s being restored :)
Fuel flap - search on here. There's a very neat trick with a clothes peg that will sort this out.
Airbag light - check wiring and connectors under the front seats for the seatbelt pretensioners. These are the cause of airbag problems 99% of the time. You'll often find that the wire has been rubbing on something and has abraded.
rwb
Post by rwb »
What a lot of mud :lol:
Lovely colour -- one of my favourites. Nice interior too -- give or take the mud :wink:
How were the links to get off? Aren't they usually rusted on solid?
Where are you jacking? I read that trolley jack on the sills is naughty.
iused to use the Tow bar as ajacking point on the 1st 406 ihad, :supafrisk:
yeah the sills are very crush-able, altho tyre fitters dont seem to think so, :frown:
dgt
Post by dgt »
Cheers for the replies! :cheesy:
lozz wrote:Looks alright that mate, 8)
I am indeed, now have 3 sets of headlights to play with!
I saw this one and said I must get a set made up!
jonsowman wrote:Good stuff, always nice to see D8s being restored :)
I prefer the look of the D8 and the IDI setup :)
I had a similar problem with the other silver car, I just swapped modules and problem solved! However, the seats are coming out (I prefer the other seats with the lumbar support) so will check them out then :D
As for the clothes peg trick, I'll have a gander for it in a bit, cheers! :cheesy:
rwb wrote:What a lot of mud :lol:
I was opting out for China blue (and still want one!) however this shade of red (regency red I believe) suits the car, hopefully staying wit me for a while :)
One side was alright to take off, the other side was a pig, I had to get out the grinder, not much room for error!
Twas jacking under the rear arms, it would be a crime to jack the sills, they're almost unmarked :shock:
lozz wrote:iused to use the Tow bar as ajacking point on the 1st 406 ihad, :supafrisk:
I've done that too with the other car.... :oops:
jonsowman
Post by jonsowman »
See now mine is supposed to be regency red and they look completely different!
What's the paint code on yours (passenger side suspension turret)?
What head lights are you using for the inside's. ?
imight make some for the 306, ive,been looking at some Fiat (polys) for the inside's.
dgt
Post by dgt »
jonsowman wrote:See now mine is supposed to be regency red and they look completely different!
EKZ, Vulcan Red! Last time I listen to that so called expert :roll:
lozz wrote:What head lights are you using for the inside's. ?
I'm going to try a set of E34 lights, I conveniently have a set brutalised already :lol:
I've dismantled Marea poly's before, bit of an arse of a job.... Take H1's btw
jonsowman
Post by jonsowman »
Ah that makes more sense. Vulcan is a lovely colour 8)
Yeah thats the ones iwas thinking of, The fiat nightmare polyelepticals
thanks for the tip, iwill leave them alone then, :lol:
Ares
Post by Ares »
Whats with the clear lights,is that a regular light milky plastic only really good cleaned or something else?
Really good 406
Who's that riding in the sun? Who's the man with the itchy gun?
Killed his wife by twenty-one....,Shot her 'cause she weighed a tone
Psy-cho Dad, Psycho Dad, Psycho Dad!
JD406
Post by JD406 »
dgt wrote:Cheers for the replies! :cheesy:
I want to know how he put Merc AMG alloys on that car. Been wanting to to that for ages to my D9.
"I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me. Your car...is your story. So don't let someone else write the book." - Moog
dgt
Post by dgt »
JD406 wrote: I want to know how he put Merc AMG alloys on that car. Been wanting to to that for ages to my D9.
That's on the cards if I can afford to get the hub adapters made up, hence the unusual set of wheels I have lined up, Merc E class wheels :wink:
More stuff done today!
These look like they've never been changed :shock:
Better
The mirror was broken, so off with the glass
Pull this one out of nowhere
Looks better!
Rebuilt the flap too, using the silver back from he other car and a clothes peg spring. Works a treat 8)
After checking the main plug for the heater fan, I decided to have a gander at the switch itself
And lose the radio in the process
Contacts were ok... Next time it's the resistor or fan to look at...
All assembled, minus that convenient phone pocket, where an MFD will reside in due time :cheesy:
Then a bit of a disaster changing a side light: the tab broke :oops:
At least I have lamps to play with...
All over this!!!
Plenty more to do :wink:
dgt
Post by dgt »
The other car is officially retired early, due to the power steering pump again. I can't be bothered!
So onto the replacement, I must press on asap... Starting with the headlights again. More pics and less yap from me!
Needs refinement
Turbo time
And off
Tis a KKK K14. Comparing it to another KKK from a van...
Cleaned up
EGR clean
This curse of a clip!
Xanti-fold :cheesy:
Yes, I know it's the same, I just wanted to say Xanti-fold :oops:
Mankey
But I got it cleaned
Clip
Cleaning the oil lines
And union
Onto the car
Filthy
Eventually
Looks bad
Sounds worse! :lol:
I took it apart to see why it broke
Scoring
Yep, snapped in the middle!
Removing a ball joint some muppet ruined! :(
Disgraceful :evil:
Cleaning up..
Better
And using the proper tool, not a chisel!
Well, to stake anyway...
Shield
Greased up
Better
Lamp
No word on gaskets, had to make my own
Refitting the whole lot
Spacers
Life savers :p
Old and new
Clean up
Oil feed pipe.... An arse to fit!
But fitted :)
Exhaust
Mounts
Split actuator pipe
ECU
Almost there...
Just the other side...
Finally for now...
Just track rods and drop links to fit. Then hopefully happy motoring for me once I sort the other niggly bits :cheesy:
