My 406 2.1TD
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Wed Jun 20, 2012 7:44 pm
Cheers Irish406, I'm very pleased with them. Very comfortable as well as good looking :)
midsmike wrote:looking gd mate you should of come to the french car show would of been gd to see ur car and wat u have done to it all you need now id new door cards and paint ur parcel shelf and a b c pillers matt black they look so much better ive done mine ill put pics up later look out for my topic
Yeah unfortunately I was busy this year, though hopefully next year I'll be coming.
I'm keeping an eye out for D9 leather door cards, looking forward to your pics etc once you've done them all. I don't have electric rear windows which might mean the D9 exec door card don't fit since they had electric windows. Need to investigate further...
Re: My 406 2.1TD
Post by lozz » Thu Jun 21, 2012 12:56 am
jonsowman wrote:Cheers Irish406, I'm very pleased with them. Very comfortable as well as good looking :)
Jon,
for the Rear cards if you dont have elec windows,
you just put a hole in the door card for the window winder,
and swap handle over, its easy to make them fit,
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Thu Jun 21, 2012 1:21 am
Cheers lozz, that's great news.
Just need to find a set of leather D9 door cards now...
Re: My 406 2.1TD
Post by highlander » Thu Jun 21, 2012 9:39 am
jonsowman wrote:Just need to find a set of leather D9 door cards now...
Had a quick look on eBay for "406 executive breaking" and found this:
http://www.ebay.co.uk/itm/130705192295
It's an estate, but the door cards are the same on the saloon and estate models. The bloke wants to sell the whole car as a non-runner but says he's willing to break it for parts. Would be worth contacting him and seeing how much he wants for his door cards.
Mig5
Re: My 406 2.1TD
Post by Mig5 » Sun Jun 24, 2012 8:47 pm
wow, those seats are the business! 8)
1999 2.0 hdi 110hp Estate in cherry red complete with A\C and also french intermittently working electrics.
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Thu Jul 19, 2012 8:59 pm
Thanks mig :)
It's been months and I've not found a scrapper in Regency Red (not a single one!), so I got an unpainted fuel flap, some primer, and a can of Regency Red. Currently waiting for primer to set.
If I've got some paint left over I'm planning to do the mirror backs :)
Will let you know how it goes.
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Fri Jul 20, 2012 5:36 pm
Put the uprated 4050 HU in today (got it for a fiver!) to replace the 4030 whose bulbs had both in the screen and I couldn't see anything.
I'd already got the MFD in from the trip computer retrofit. Very happy :)
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Sat Jul 21, 2012 6:25 pm
Decided to wire up the temperature sensor. What a total ***** of a job!
Pass side door card and mirror off to examine the loom, no sign of wires 721 and 722 which are the temp sensor wires leaving the trip computer bank. After removing a tonne of trim on the interior, I found the plug that is the connection between the door and the body. Wires 721 and 722 stop at this plug.
The hole is very well sealed (for waterproofing reasons I assume) so I tried to push wires through unused holes in the plug, but they have white bungs in them which took me a long time to work out, and even when these are removed, the hole remaining is tiny. So I used a Dremel to widen two holes to feed cables through. Access is really restricted in this bit!
Then fed the wires through the rubber concertina and into the door with a lot of difficulty, and then up to the mirror.
I've got a thermistor on order, so when that turns up all I have to do is remove the mirror and attach the sensor :)
This really wasn't an easy job, if you're thinking of attempting it, give yourself a whole afternoon and lots of tea!
midsdaz
Re: My 406 2.1TD
Post by midsdaz » Sat Jul 21, 2012 11:37 pm
How easy was the trip on the mfd I wouldn't mind doing that
Myself
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Sun Jul 22, 2012 12:36 am
midsdaz wrote:How easy was the trip on the mfd I wouldn't mind doing that
Myself
Here you go :)
viewtopic.php?f=10&t=16864
midsdaz
Re: My 406 2.1TD
Post by midsdaz » Sun Jul 22, 2012 8:55 am
Thanks Mate i couldn't find it when inha a look
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Wed Aug 01, 2012 6:29 pm
Finished the filler flap today. Two coats of primer, two paint and two of lacquer, two weeks for the lacquer to harden and then a good polish with some T-cut.
Very pleased with the colour match, and I don't even need the "clothes peg spring" trick any more since the original spring is working again!
New one on the car:
Holding the old one up against the car to compare:
midsdaz
Re: My 406 2.1TD
Post by midsdaz » Wed Aug 01, 2012 7:23 pm
Looks good mate I got to do mine driving around the roundbout every time I want the flap open isn't fun anymore
Roylewaa
Re: My 406 2.1TD
Post by Roylewaa » Thu Aug 02, 2012 11:08 pm
Looks a top match there mate, nice one 8)
D8 2.1 TD saloon, oh yeah :)
jonsowman
Re: My 406 2.1TD
Post by jonsowman » Mon Aug 20, 2012 7:21 pm
218k miles, had a new Valeo clutch, bottom engine mount, driveshaft oil seals and input shaft seal done today, along with a short service.
It's made a huge difference, feels fantastic to drive.
Must say thanks to KrisB (http://krisb.co.uk) for his excellent work, would recommend him to anyone!
