Having to slam estate tailgate
bigknickers
Post by bigknickers » Wed Mar 28, 2018 8:46 pm
Ever since an old boy whacked me up the back end (no damage) I have had to slam it to get it to shut, I'm steadily having to increase the force and soon I'll find the car on the other side of the road!!!...............do I adjust the lock in the tailgate or the one in the slam panel n how do I do it?
PeterN
Re: Having to slam estate tailgate
Post by PeterN » Thu Mar 29, 2018 11:42 am
Adjusting the striker plate should fix this, there should be a couple of screws into the floor which when loosen'd will allow the latch to move for and aft, move out away from the car slightly then tighten the screws, not to far out though or it will rattle. You could try applying a little oil or grease to it first.
bigknickers
Post by bigknickers » Thu Mar 29, 2018 8:13 pm
Thanks Pete, I'll have a go once it stops raining
bigknickers
Post by bigknickers » Wed Apr 11, 2018 4:43 pm
Peter you're a genius.............the tailgate shuts wonderful!!!!
dirtydirtydiesel
Post by dirtydirtydiesel » Wed Apr 11, 2018 9:08 pm
You could have just wound in the rubber stoppers on each corner of the tailgate, same effect just easier :roll:
Just like the ones on the bonnet, has your tailgate allways been difficult to shut ?
or has it had some work at the rear end, wouldn't have left the factory like that
& they get losser though use not tighter :?
:supafrisk: just read the org post , please feel free to ignore me :oops:
Post by Welly » Thu Apr 12, 2018 8:09 am
I've often found striker plates need a little adjustment as a car ages, bump damage aside they do tend to need a littke tickle to account for shrinking door rubbers and hinge wear etc.
Tailgates are interesting as they can take quite a few goes to balance the thing shutting easily against it being too loose as Peter said.
2005 Volvo S40 T5 German Diesel botherer/i]
Post by Doggy » Thu Apr 12, 2018 12:47 pm
FFS don't post that anywhere the Audi brigade can see it
