New Member
Metalman
New Member
Post by Metalman » Sat May 26, 2018 5:55 pm
Hi all.
Just joined. I have three 406's A MK1 Saloon and two Estate later estates (110HDi's)
Was looking for some solutions to the problems that I have and came across the forum. Lots of useful info on here so I thought I had better join up.
I have loads of questions which will no doubt generate more questions..... :roll:
97 1.9TD Saloon
99, 110 HDi LX Estate
99, 110 HDi GLX Estate In need of a Gearbox (ML5T)? down to select reverse .....
Re: New Member
Post by GingerMagic » Thu May 31, 2018 7:15 pm
Hi, welcome :cheesy:
This forum is pretty good for technical help and guidance, although it's a bit quiet of late....
Have a peek through the Knowledge Base on the home screen for possible solutions, otherwise just post up whatever questions you have and we will try to help you get to the bottom of it 8)
Also, please take 5 mins to add your location to your profile then maybe someone local with diagnostic equipment can swing by.
Kelv
1999 T4 family wagon
2005 Vauxhall Meriva
Re: New Member
Post by Doggy » Thu May 31, 2018 9:56 pm
Hi & Welcome aboard. 8)
As GM says, it's getting a bit quiet, but still lots of good advice (& some of mine) to be had for the asking.
Pull up a chair.
