Bawkicker406
Post by Bawkicker406 » Thu Aug 09, 2018 4:47 pm
Hi folks, just making myself known, been driving a 306 cab for the last year. But have now got a 406 s hdi estate. Loving the car. Loving the space, it has a few issues which I will work my way through. But I feel I'm going to have issues fixing the MFD. Which is a type c, has anyone tried to fix the display due to lines on screen? I know you need ACF, however. Does anyone know if there is a company or person, who can refurbish them?
Many thanks :cheesy:
caprixpack
Re: Newbie
Post by caprixpack » Thu Aug 09, 2018 7:57 pm
Welcome along, get some pictures up 8)
Re: Newbie
Post by GingerMagic » Thu Aug 09, 2018 8:07 pm
Hi, welcome to the club :cheesy:
The 406 is a great all rounder, but I guess you know that already.!
The type C is prone to failing, and several people have tried to fix it using various methods but so far nothing is intricate enough to do it....
If it bothers you, you can fit a Type B instead - its not as pretty but perfectly functional.
How's your handbrake :lol:
1999 T4 family wagon
2002 Citroen Xsara Picasso Hdi90
2003 Hdi110 Executive estate
Bawkicker406
Re: Newbie
Post by Bawkicker406 » Thu Aug 09, 2018 9:19 pm
thanks guys....yeah the handbrake is a little hit or miss.....it holds....just.....but stick it under load and it doesn't hold the car...so I guess it needs adjusting...….A question on putting in the type b, can it be from any 406? because I have seen various type B for sale and every one of them has said "make sure the part number match". what does this mean?
many thanks :cheesy:
Re: Newbie
Post by GingerMagic » Thu Aug 09, 2018 10:54 pm
Means nothing, sellers are just covering themselves..
Try to find one from the same age car as it saves having to adjust the BSI if it's not the same..
Older cars have a wired stereo control stalk, newer cars are Can-bus - this can be altered with diagnostic equipment but easier to get one from the same era.
Handbrake is easy to adjust using the adjusters in the rear hubs, but Jasper5 did a proper guide on the knowledge base, on the home screen - much more thorough than a simple tweak.
Bawkicker406
Re: Newbie
Post by Bawkicker406 » Thu Aug 09, 2018 11:00 pm
That's great, thank you, will start looking for a MFD that doesn't cost the earth :lol:
Re: Newbie
Post by GingerMagic » Thu Aug 09, 2018 11:31 pm
Try to find one that shows it works okay, although it's only 3 little bulbs in the back of them if it's a bit dark...
What year is your 406?
Bawkicker406
Re: Newbie
Post by Bawkicker406 » Thu Aug 09, 2018 11:38 pm
2003
Re: Newbie
Post by GingerMagic » Thu Aug 09, 2018 11:47 pm
Cool - any MFD from 2001 will be fine, older ones may need tweaking but worth it if it's cheap :cheesy:
Bawkicker406
Re: Newbie
Post by Bawkicker406 » Thu Aug 09, 2018 11:51 pm
Cool. I will get that looked into, thanks for all the information
